Author Topic: Any idea what kind of heads these are?  (Read 11732 times)
Offline c10dude75
« on: August 19, 2015, 11:09:03 pm »
Yeah was just curious as to what kind of heads these are tried looking up pictures to see what they might be. I did find something similar but still wasn't it. If anyone knows feel free to comment thank you👌.
Offline Don5
Re: Any idea what kind of heads these are?
« Reply #1 on: August 19, 2015, 11:34:45 pm »
There should be a number stamped into the inside of the head. You use the last three digits to decode the head.
Offline c10dude75
« Reply #2 on: August 19, 2015, 11:53:45 pm »
Alright ill have to check that out thanks man👍. But yeah I bought this truck about a month ago it looks like it was semi speedy at 1 point so trying to find out what kind of secrets it's hiding haha.
« Reply #3 on: August 20, 2015, 01:16:41 am »
kind of hard to see from the angle and grime on there
does this help?
Offline c10dude75
« Reply #4 on: August 21, 2015, 07:42:48 pm »
Yeah seen the chart before that's why I was asking cus I didn't see it on there. Thank you for the help hopefully get to the bottom of this soon.
« Reply #5 on: August 21, 2015, 07:54:55 pm »
could you get a better picture?
Offline LTZ C20
« Reply #6 on: August 21, 2015, 08:05:41 pm »
That is the casting mark I boxed in red in Irish's post. It is reversed but that is it.
LTZ Cheyenne C20
Offline enaberif
« Reply #7 on: August 21, 2015, 08:46:21 pm »
3927185....69-76...307/327/350..70cc chambers
3986339....71......307/350......74cc chambers
The 339 would be better than the 185 but once you get the numbers be easier to tell
Offline c10dude75
« Reply #8 on: August 22, 2015, 12:24:17 pm »
Yeah I was going to say looked like that L shaped 1 but wasn't sure since it was pointing the other way thought they might of been different but thank you for clearing that up. And alright ill have to look either later today or tomorrow to find out for sure the number.
Offline c10dude75
« Reply #9 on: August 23, 2015, 09:41:21 pm »
So I looked under the valve cover found this number looks like it says 186? But on that chart it be a different head and that's not possible cus looks nothing like that other head symbol. Also found out the gas is in the oil and when I bought it dude said it had a sticky lifter at full throttle which I comfirmed. But could it just be cus the oil is to thinned out and it's just not oiled properly?
Offline enaberif
« Reply #10 on: August 23, 2015, 09:47:16 pm »
3927186....69-70...302/350......Camel hump,64cc chambers,accessory holes
An ok head but nothing that great. 64cc chambers are pretty small.
« Reply #11 on: August 23, 2015, 09:49:49 pm »
gas in oil can be from a bad fuel pump diaphragm. if you let the truck sit for a couple days of so does it seam to take a couple more cranks than normal to start?
Offline Don5
« Reply #12 on: August 23, 2015, 09:53:15 pm »
Offline enaberif
« Reply #13 on: August 23, 2015, 09:53:54 pm »
Gas in oil can also be from a leaky carburetor
Offline c10dude75
« Reply #14 on: August 23, 2015, 11:51:12 pm »
Yeah got to pump the gas pedal 3 times then it starts. Kid I bought it from been doing that since he got it. also might have leaky carb cus there is what looks to be gas caught in the torker intake like might of been running down or flooded i don't know. And wouldn't 64cc create higher compression? And thanks for the link ill have to check that out. maybe ill take a pic up close of the carb so can see what's going on.
