Author Topic: Differential gear ratio questions  (Read 26495 times)
Offline Magic1
« on: August 19, 2015, 11:24:21 pm »
My 82 Sierra 4x4 is running a 350/th350 with 35 inch tires, 3.08 gears, an open front diff and a locker in the rear. The spider gears were shot in the rear end and to save money I installed a spartan locker which I hate. I'm going to replace the differentials with limited slip front and rear and regear the truck. I won't say it's terrible at takeoff and power now but it could certainly be better. The question I've got is what are a lot of you guys running as your gear ratio with the same tire size/transmission that I have? I've looked at several gear calculator charts and they all show for a broad range of power and mileage to go between 4.10 up to 4.88 for that particular tire size. That seems like quite a jump to me but I'm not sure. I wanna do it right the first time. Just looking for some opinions from those that are running a similar setup.
Re: Differential gear ratio questions
« Reply #1 on: August 20, 2015, 10:40:17 pm »
I think I would go with 4.56 or 4.10 if you don't have overdrive.
Offline Magic1
« Reply #2 on: August 21, 2015, 02:26:27 am »
I appreciate your response. I talked to a Drivetrain-Differential shop yesterday and they advised me to go with the 4.56. Said they do a lot of them.
« Reply #3 on: August 21, 2015, 02:42:03 am »
4.56 and 35s you will be screaming trying to keep up with traffic with no od. i had 4.10 with 38s and no od wish i had 3.73. now if you mud yeah you might miss it but thats what 4low is for
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #4 on: August 21, 2015, 03:09:54 pm »
4.56 is going to make your truck seem a lot quicker in the zero to 55 speed slot. It's a good choice.
« Reply #5 on: August 21, 2015, 03:34:22 pm »
I have a 4.56 in my Yellow extended cab.  I dislike (HATE) it.  Even 50 mph the engine is screaming.  If you never had to go on the highway, probably be ok. If you were running 38's or 44's, a 4.56 would be a good gear.  My $.02
« Reply #6 on: August 21, 2015, 04:24:15 pm »
even in my 91 i have 4.10 and only 29s i think if not smaller. with od im around 2k just going 60. might not be too bad in a gas motor but im losing my mpgs with the cummins.
with 4.56 and 35s you'll be at 3k going 65 and at 55 youll be close to 2500
Offline pholliday1
« Reply #7 on: August 21, 2015, 08:35:18 pm »
Zieg what size tire are you running with those 56's.
« Reply #8 on: August 21, 2015, 08:53:33 pm »
LT265/75R16
Offline pholliday1
« Reply #9 on: August 23, 2015, 05:24:31 pm »
Yea I see what you mean 4.56 gear is in the basement for that tire size.
Offline Magic1
« Reply #10 on: August 24, 2015, 03:43:16 pm »
Wonder how much difference I would be able to tell in going up to a 3.73? With it being so much I wanna do it right the first time and have no regrets but I also don't want to spend the money and not be able to tell much of a difference. Seems like now I'm running around 2200 rpms at 70 or so with the 3.08s. I don't want it to be screaming on the highway but I don't drive it at 70 all that often either. Just want to find a good balance. Also I built the truck for all around use; hunting, hauling trash, getting to work in bad weather. I don't intend on mudding it but rather have something that'll get me there and back if I have to get in some slop.
« Last Edit: August 24, 2015, 03:47:03 pm by Magic1 »
Offline ehjorten
« Reply #11 on: August 25, 2015, 09:07:48 am »
I have 4.10s on my '91 with 35s, but I have OD.  I can fly down the highway with ease.  At 75 I am only turning about 2,100.  For you, without overdrive, the same effect would be close to what you have now.  If you went with 3.73s you would be turning about 600 RPM more and in my opinion, wouldn't be too bad if you driving on the highway fairly often.  I turn about 2,900 in my '69 Chevelle going 75 and it is more than comfortable doing that.
In my '77 I also have 4.10s, but without overdrive and with 33s.  In that I am turning about 3,100 to go 75 and it is just too much to drive that fast on the highway for long periods.  It is loud and it is fatiguing!  Around town it is just fine!
-Erik-
Offline Magic1
« Reply #12 on: August 26, 2015, 03:11:39 am »
The more I think about it the more I'm leaning towards 3.73. I think anything lower would be a waste of money and the 4.56 would be too low without od. Jury's out on the 4.10, may like it better but I think the 3.73 would probably work the best for what I use it for
Offline Gusgusa1
  • Gasket
« Reply #13 on: September 01, 2015, 08:50:18 pm »
4.91 that's what I have. She jumps pretty good but revs ( 3000)  at highway speed. 33" tires.
2002 gmc 1500hd 6.0 4x4
1987 gmc Sierra classic 1500 350ss 4x4
1986 silverado 350 4x4
1984 scottsdale 305 quad jet 4x4 4spd manual
1982 camaro z28 350 w vortec heads spool
Offline rich weyand
« Reply #14 on: September 01, 2015, 10:08:34 pm »
I'm running 3.73 with 31s on a K truck.  Mostly around town, but the occasional 200-300 mile run and back.  I think it's about perfect.  2500 rpm at 60, give or take.  So 4.10 would be my bet.
