Author Topic: Throttle cable too short?  (Read 16927 times)
Offline Gusgusa1
  • Gasket
« on: August 21, 2015, 11:20:45 pm »
I need help. I have a 1987 gmc with 350 tbi. Throttle cable broke and I replaced it. Problem is its a couple millimetres short so it revs the engine hard core. Can I adjust the cable at all? Or should I mess with the throttle position sensor?
Options? Please.
2002 gmc 1500hd 6.0 4x4
1987 gmc Sierra classic 1500 350ss 4x4
1986 silverado 350 4x4
1984 scottsdale 305 quad jet 4x4 4spd manual
1982 camaro z28 350 w vortec heads spool
Re: Throttle cable too short?
« Reply #1 on: August 22, 2015, 12:39:24 am »
Pioneer CA-8314 is 28.8" long and fits all '87-91 R/V trucks with TBI.  What did you install?
Does it idle down properly if you disconnect the cable?
Offline Gusgusa1
  • Gasket
« Reply #2 on: August 22, 2015, 08:57:04 am »
Yes, I got it online.  Do I just give the bracket an ever so slight bent forward or do I mess with tps?
« Last Edit: August 22, 2015, 10:04:27 am by bd »
Offline Gusgusa1
  • Gasket
« Reply #3 on: August 22, 2015, 10:01:14 am »
Only One more thing to break before it goes to a pro
« Reply #4 on: August 22, 2015, 10:07:52 am »
Do not alter the TPS adjustment as it will not help the symptoms, but will introduce other problems!
If you unhook the cable from the accelerator pedal under the dash, will the cable extend far enough to let the engine idle properly?
Offline Gusgusa1
  • Gasket
« Reply #5 on: August 22, 2015, 10:27:30 am »
Yes.
« Reply #6 on: August 22, 2015, 11:07:00 am »
Get a helper and a flashlight.  With the cable reattached under the dash and the accelerator pedal pressed to full throttle, does the TBI throttle plate open all the way to vertical?
Offline Gusgusa1
  • Gasket
« Reply #7 on: August 22, 2015, 03:48:09 pm »
Grabbed a crescent wrench and bent the bracket also took a drill bit that was ever so slightly larger than the hole and shaved a hair out of the hole.
The issue was the geometry. Since the cable wasn't straight with the connector between the bracket cable and linkage it bowed out in an arc toward the drivers fender. With some tweaking it is now better but not perfect. The cables are over 60$ in canada so I was understandably miffed that it didn't fit.
 It moves the range it should and is smooth.
Thank you for the help :)
« Last Edit: August 22, 2015, 05:08:04 pm by bd »
« Reply #8 on: August 22, 2015, 05:35:52 pm »
...The issue was the geometry. Since the cable wasn't straight with the connector between the bracket cable and linkage it bowed out in an arc toward the drivers fender. With some tweaking it is now better but not perfect....  Thank you for the help  :)
You're welcome.
So there was more to the story than just a replacement cable that didn't fit....  Any idea why there is a geometry/alignment problem?  Is it modified from the original factory configuration?
If it makes you feel any better, I had to fabricate custom adjustable brackets for cruise transducer, TV cable and throttle cable when I converted my 87 to MPFI.  Achieving the correct angles, offset and extension was time consuming.
Offline Gusgusa1
  • Gasket
« Reply #9 on: August 22, 2015, 06:31:41 pm »
I don't know all that's been done to it. But this is what I gather
- light wieght pistons
- headers
- H pipe exhaust
- throttle body spacer
- 400 crank
- hyper tech program
- throttle body is modded
- LSD front and back
- some kind of cam
- 12 second truck
I got it from a widow whose husband passed last winter, so the secrets passed with him.
Offline Gusgusa1
  • Gasket
« Reply #10 on: August 22, 2015, 06:34:41 pm »
It has always been a stiff throttle at the start. No easing off the line lol. Trying to figure that out.
Offline Gusgusa1
  • Gasket
« Reply #11 on: August 29, 2015, 11:49:46 am »
Throttle moves free at the tbi and peddle moves free when cable unhooked any idea why I almost have to stand on it to begin depressing the cable?
Offline timthescarrd
« Reply #12 on: August 29, 2015, 12:20:42 pm »
The throttle cable should be long enough to make a gentle loop in the engine bay, this allows for flexing as the engine moves and prevents binding.  If your cable is a straight run from the firewall to the cable bracket, it is way to short and probably binding up
« Reply #13 on: August 29, 2015, 12:47:19 pm »
Timthescarrd states a valid point.  Still, from what you posted previously, this has been a longstanding problem that preexisted your recent replacement of the throttle cable using a cable cataloged for your specific application.  Posting some pics might clarify what you are running into.
What did you mean by, "the throttle body is modded?"  Are you relying on the stock TBI throttle return spring incorporated with the base or has an external spring been added?  Is the cable aligned 90° to the throttle shaft and parallel with the valve cover?  Perhaps the cable entry angle to the throttle lever arm is too severe.  Is the TPS sticking.  Are all the throttle levers secure?  Does it have cruise control?
Offline Dr_Snooz
« Reply #14 on: August 29, 2015, 10:27:05 pm »
x2, if you have any kinks or sharp bends, you'll have a lot of trouble with stiffness and sticking.
