Author Topic: Lift Spring Amount  (Read 7638 times)
Offline enaberif
Lift Spring Amount
« on: August 22, 2015, 11:03:46 pm »
I installed what I thought and was told were 4" springs. When I put everything together and took the weight off and let it sit on the ground it looked like this. Now I know that this is not 4" but I'm thinking maybe 2" but its still weird how its arched. So maybe its a stock spring replacement? Any ideas? No visible markings on the springs.
If I placed them on the ground and measured could I do floor to top of spring?
« Last Edit: August 23, 2015, 09:12:06 am by enaberif »
Re: Lift Spring Amount
« Reply #1 on: August 23, 2015, 03:36:41 pm »
dont know why but i cant see the picture
Offline enaberif
« Reply #2 on: August 23, 2015, 04:28:56 pm »
I've been having issues with my host.. here...
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #3 on: August 23, 2015, 05:29:52 pm »
It's a negative arch spring which "appears" like a factory one ton spring.
Offline enaberif
« Reply #4 on: August 23, 2015, 05:48:21 pm »
Yeah its just bizarre because these are narrower than stock springs and have yellow writing on them which you can't read.
