Author Topic: Which printed circut do i need?  (Read 4021 times)
Offline philo_beddoe
  • 77 C-10
« on: August 24, 2015, 10:26:31 pm »
The catalog shows three different ones i can order: warning lights, guages and guages with tach. I have no tach so i'm down to two.  I have a basic 77 bonanza.  My printed circut is all tore up, a couple of lights will not work.  What do they mean "guages or warning lights"?  Thanks.
Offline AZ87V10
Re: Which printed circut do i need?
« Reply #1 on: August 25, 2015, 07:26:21 pm »
It depends on whether you have gauges to the left of your speedometer or not. I.e., does your truck have oil pressure, temperature, and voltmeter gauges or not? If it does, you'll need the printed circuit for gauges. If your truck has blank spots there with just the words on them for those functions, then you need the printed circuit for warning lights. Trucks with gauges had warning lights under the speedometer and fuel gauges, while trucks with just warning lights had the lights to the left of the speedometer in place of the gauges. Hope this helps you.
  • 77 C-10
« Reply #2 on: August 29, 2015, 03:11:15 pm »
That helps a whole lot.  I have guages.  However, i did fix the printed circut board.  Thanks.
