Author Topic: Pulley Grooves - A/C Delete  (Read 4994 times)
Offline harcorshe
« on: August 25, 2015, 06:22:57 pm »
1978 K20 454 TH400
The P.O. said the A/C hasn't worked in years, and after pricing replacement parts, I decided to ditch it. I have ordered the "A/C Delete" panel and I am trying to determine what else I can get rid of/clean up.
I have searched Google images and the Service Manual, but can't get a clear look at a Non-A/C pulley set up.
Can I go with a single groove pulley for the power steering pump? (Belt from crankshaft to P/S)
Still need a 2 groove water pump pulley? (Belt from crankshaft and Belt to alternator)
Can I go to a 2 groove crankshaft pulley?  (Belt to P/S and Belt to W/P).
Thanks for any help!!
'78 K20
454
TH400
14 Bolt
205 Transfer Case
Re: Pulley Grooves - A/C Delete
« Reply #1 on: August 27, 2015, 10:54:43 pm »
Why not just remove the compressor, mount and the belt.
Offline harcorshe
« Reply #2 on: August 28, 2015, 10:17:26 am »
I guess I've become a little compulsive about cleaning up the engine bay in the process of changing out some of the accessories.
BTW, this is a hobby, and, of course you're right; I probably don't really need to do most of the stuff I (try) to do this truck. But it gives me hours of enjoyment!
Thanks!
'78 K20
454
TH400
14 Bolt
205 Transfer Case
