Author Topic: 1986 drive shaft  (Read 4617 times)
Offline 86charcoalsierra
1986 drive shaft
« on: August 26, 2015, 02:05:49 am »
I recently installed a 454 out of a 1985 Chevy Truck into my 1986 gmc Sierra. Also put in a 400r transmission out of same truck I had a 305 in my truck with the 350 transmission. I used the drive shaft that I had but it is about 2-3 inches to short. So it leaks alot of transmission fluid. Need some help on what drive shaft I can use or if any body know where I can get one around fort Worth tx. My truck is a short bed with stock differential. Thanks for the help.
Re: 1986 drive shaft
« Reply #1 on: August 26, 2015, 08:55:30 am »
the way i see it your th350 should of been about 27 11/16" long the th400 is about 28 3/8" long. so the driveshaft should fit good, the problem you might be having is just a bad seal
« Reply #2 on: August 26, 2015, 01:53:40 pm »
I already replaced the seal. You can see in the picture that I need about 3 more inches I'll have to measure to be sure. The slip yoke is only about half inch inside transmission. The yoke on back of the transmission had a nut so it was flush with the back of the transmission. When I went to install drive shaft it was to short so I took the nut off and pulled the yoke out until it would reach. It's bearly in there pretty sure if I hit a good bump and catch some air the shaft Will fall off.
« Reply #3 on: August 26, 2015, 02:13:43 pm »
ahh so you had a bolt on yoke and now you have a slip. this changes things a little
« Reply #4 on: August 26, 2015, 02:19:20 pm »
Yes that's what happened any ideas.
Offline roundhouse
1986 drive shaft
« Reply #5 on: August 27, 2015, 07:25:05 am »
Pick up the right shaft at a junk yard
Even if it's too long
Lot cheaper to get it cut down shorter at a drive shaft shop
You have to have a slip joint
Either in the shaft or in the transmission
But you can't have two
« Last Edit: August 27, 2015, 09:20:49 am by roundhouse »
« Reply #6 on: August 27, 2015, 07:56:19 am »
yeah thats about all i can think of. put the bolt back in the yoke and measure from yoke to yoke then go to the yard and find a driveshaft with a similar size and Basic stub and slip yoke type driveshaft
