Author Topic: FLIPPING REAREND WITH CAL-TRACS  (Read 5081 times)
Offline BIG RED 1983
« on: August 26, 2015, 07:29:20 pm »
I NEED EXPERIENCED ADVICE ON HOW TO FLIP THE REAREND WITH THE USE OF CAL-TRACS. I KNOW CALVERT 3204 IS THE CAL-TRACS PART NUMBER I WILL USE HOWEVER I DO NOT HAVE A CLUE WHAT TO USE TO DROP IT. THE TRUCK IS A LONG BED AND WILL RUN 12'S WHEN I AM DONE. I NEED WHATEVER I USE TO BE OF REALLY GOOD QUALITY. ANY HELP WILL BE APPRECIATED.
Re: FLIPPING REAREND WITH CAL-TRACS
« Reply #1 on: August 27, 2015, 10:43:54 pm »
Any flipkit will work, but I would stick with good quality name brands with the saddle on them.  Belltech or Western Chassis is what I use.
If you are going to be drag racing it, I would consider researching better springs that what was designed to carry a load in the bed...
This is the Caltracs you need...
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=CAL-3204&Category_Code=SUSP
« Reply #2 on: September 01, 2015, 07:05:25 pm »
I APPRECIATE YOUR RESPONSE. I THINK INSTEAD OF USING A FLIP KIT I WILL JUST USE LIKE COMPETITION ENGINEERING SPRING PERCHES AND WELD THEM TO THE REAREND HOUSING.
