Author Topic: QUIET TURBO TYPE MUFFLERS???  (Read 9755 times)
Offline kfoz
  • ALWAYS BUILD WITH BRICK & STONE ! ! !
« on: September 01, 2015, 08:47:45 pm »
MY 76 HAS 2 1/4" DUALS WITH THRUSH MUFFLERS(FLOWMASTER TYPE CASE) and the drone noise inside is awful ! ! !
What turbo type mufflers are out there these days that flow like a flowmaster but have NO DRONE inside the cab???
Thanks!
kfoz (kfoz@comcast.net)
'73 C20 4 Speed 2WD
Offline outlaw70nova
Re: QUIET TURBO TYPE MUFFLERS???
« Reply #1 on: September 02, 2015, 10:18:39 am »
I'm assuming that you don't have tailpipes. Taking the exhaust all the way out the back will cure that problem.
Offline reed85
« Reply #2 on: September 02, 2015, 01:12:09 pm »
I dont know if u like glass packs but i got 24 inch flowtech glass pack that sound great after they broke in they got quieter but sound grean inside and outside the cab and real cheap
Reed85C30
Offline timthescarrd
« Reply #3 on: September 02, 2015, 01:29:46 pm »
Where does your exhaust exit?  I've got long tube headers, dual 2 1/4 exhaust, Thrush turbo dual-offset mufflers, piped straight out the back on my long bed with very little drone.
Offline kfoz
« Reply #4 on: September 02, 2015, 08:39:56 pm »
My exhaust is full WITH tailpipes,  2 1/4", exiting at an angle behind the rear wheels.
Again, awful drone while idling.  I want quiet but a slight throat upon acceleration.
'73 C20 4 Speed 2WD
« Reply #5 on: September 03, 2015, 06:49:03 pm »
Magnaflow and Dynomax have never droned on my trucks.
I am running Pypes Race Pros on mine and they are QUIET.
Offline square81
« Reply #6 on: September 04, 2015, 10:06:26 pm »
I've got 2 1/4 duals with Cherry Bomb turbo mufflers. My tail pipes go all the way out. No drone and sound good at highway speed.
Offline Shifty
  • I bleed Bowtie red...
« Reply #7 on: September 05, 2015, 02:31:45 pm »
I'm running a welded Ultra-Flo Dynomax, and it sounds fan-flippin-tastic.  It makes me wish I had more engine... :-\
98 C2500 ext cab longbed
Offline SkinnyG
  • Reducing resale value since 8-track days
« Reply #8 on: September 05, 2015, 10:25:17 pm »
I have Dynomax Super Turbo, and they are almost too quiet.  I, too, can't stand drone.  Not sure if I should have gone Magnaflow instead, but with the Super Turbos, my wife and I can hold a conversation in the cab.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Offline kfoz
« Reply #9 on: September 06, 2015, 03:09:49 pm »
Thanks skinny..  I WANT too quiet!  I'll check it out!
'73 C20 4 Speed 2WD
Offline SkinnyG
« Reply #10 on: September 06, 2015, 11:03:39 pm »
Sounds A LOT like THIS, except this was with Walker SoundFX mufflers (don't get those).
Offline kfoz
« Reply #11 on: September 07, 2015, 09:21:27 am »
I ordered the Super Turbos from Summit ! ! !   Hope I love them!
'73 C20 4 Speed 2WD
« Reply #12 on: September 08, 2015, 10:14:23 am »
Unless something has changed you will like them.  That is what I ran.
Offline kfoz
« Reply #13 on: September 08, 2015, 04:32:15 pm »
It's quite amazing how once we creep into our late 40s that we want what our Dads liked when we were kids!!!  QUIET exhaust!!!!!!!!!!!!!!!!!!!!!!
Plus it doesn't do me any good that I have noise sensitivity from over 20 years of being a brick & stone mason ! ! !  >:(
'73 C20 4 Speed 2WD
Offline mcintyrederek
  • Rookie
« Reply #14 on: September 08, 2015, 07:36:21 pm »
You might be satisfied with the mufflers you have already if you installed a crossover pipe.  It takes out that annoying resonance that you probably have at a certain RPM band.
I have cheap glasspacks on my lightly cammed 350 with true duals (no crossover pipe) and the drone noise is out of this world between 40 and 50 MPH, translation, 1600 to 1800 RPM.  Below that it's fine.. above that, it stops resonating.
A friend with a C20 and the same setup installed a crossover pipe with glasspack tubes and it totally cancelled out the resonance but still sounded killer out the back.
There is a certain place, ie, length back from the exhaust manifold that the crossover pipe goes for best effectiveness.  How it's calculated, I'm not sure, but I'm interested now, so I'll Google it.  Attached picture is just one example.
Mack.
1986 C-10 Silverado 350 CI 260 HP, Edelbrock 1405, TH400, 2.73's - rescued from the junkyard - Farm Truck, daily driver!
