Author Topic: Loosing battery power  (Read 3468 times)
Offline cwest
« on: September 02, 2015, 07:13:16 pm »
86' K20.  For a while now I've had a flickering battery gauge.  I took real notice when driving at night and all of the trucks lights dim randomly, sometimes to the point of no light at all.  I Googled it and the first thing that popped up was bad alternator, so I swapped in a new one, to which nothing changed, still flickering lights and battery gauge.  I jiggled every wire I can see looking for a short, but nothing.  The only thing I've found that distinctly causes a dim in lights is if I step on the rear passenger side bumper.  Does this still sound like a short somewhere, or is this something specific someone has dealt with?  It happens predominantly after the truck is up to temp as well.
86' Chevy K20
350/SM465/np208
08' Silverado 1500 4X4 WT
Re: Loosing battery power
« Reply #1 on: September 02, 2015, 08:18:27 pm »
How strong does the starter crank the motor?
It sounds like a connection problem... somewhere.
To begin, take a thorough look at the following:
  • battery terminal and cable condition - realize that cable strands can corroded and break inside the cable jackets where hidden from view.  If you see green fuzz, replace the cables with at least 2-gauge all copper battery or welding cables.
  • battery cable connections to the battery, starter and engine block or alternator bracket
  • ALL of the remaining grounds (battery-to-radiator support, battery-to-frame, right rear cylinder head-to-cab, instrument panel-to-cab, rear lamps-to-bed sheetmetal, and bed-to-frame)
  • tightness and condition of all wires connecting to the alternator
  • condition and tightness of the fusible links at the starter solenoid and firewall junction block
  • heavy-gauge red B+ feeds as they run through the conduit in the vicinity of the right exhaust manifold and up behind the engine, inspecting for burning and/or chafing
  • heavy-gauge red B+ feeds where they pass through the firewall bulkhead connector, inspecting for heat stress and melting of the connector body
  • the splice in the heavy-gauge B+ feeds taped into the harness under the dash near the fuse block (this one is a pain - save it for last)
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #2 on: September 02, 2015, 08:22:31 pm »
Double check grounds, battery to frame, frame to engine, and frame to cab. Sometimes these corrode internally too, so replacing to rule it out may be the best choice.
 1986 Chevy K30(under repair)
Offline cwest
« Reply #3 on: September 03, 2015, 12:21:33 am »
The starter turns the engine normally except about 1/10 starts it stutters for a half a second before cranking.  Having said that I'll probably start with the starter connections, and then the rest of those suggestions.  I'll you guys know, thanks for the replies
86' Chevy K20
350/SM465/np208
