Author Topic: chevy old paint removal  (Read 5997 times)
Offline robertchevy77
« on: July 29, 2004, 05:28:00 pm »
hi need help with my chevy silverado 1977.  I want to start removing the old paint but i dont know how or with what to start with I would be very thankfull if u could give me some pointers or tips on how to do an excellent job
Offline roundedline
Re: chevy old paint removal
« Reply #1 on: July 29, 2004, 05:22:00 pm »
If the paint is in fair condition as in just not shiny and not really flaky rusty then it will be the best base coat.  You can just sand it down.
If you are dead set on stripping it to the metal, you can use a chemical stipper.  If you plan to get it professionaly painted, or if you plan to just get someone else to paint it, talk to them and see how they think you should go about prep work.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
« Reply #2 on: July 29, 2004, 09:04:00 pm »
well what would u recommend a begginer with a real real real real real tight budget to do and what would u estaimate the cost would be and this is the way in which i am planning to paint my truck in the future  http://www.4x4wire.com/feature/daveniles/dave1.jpg
Edited by: robertchevy77 at: 7/29/04 8:05 pm
Paint
« Reply #3 on: July 30, 2004, 10:18:00 am »
I would not recommend a beginner to completely strip a truck. Unless it has been painted more than one or the last job was hacked or of poor quality materials. If it is the original paint I would stick with repairing any damage and blending those areas into the paint with high build urethane primer. Feather sand any scratches and hit them with primer as well. Sand the rest of the paint and primed areas with 320 or 400 so the new paint will stick. You will do your self a few big favors by (1) buying a good book on body and paint how to info and maybe making Friends with a pro that is willing to share some knowledge. (2) You don't have to buy the most expensive materials on the shelf. Middle of the road prices are usually decent quality materials, shop around a bit.  Don't use cheap masking tape and don't leave it on overnight ( even the good stuff ) if you are working out side. 3M tape is what you want. Any moister and then sunlight will make it almost impossible to remove. Good luck, and feel free to ask about different brands and tech. questions.
