Author Topic: What size tire will fit on Stick Rallye wheels?  (Read 12983 times)
Offline 82FinkK10
« on: September 08, 2015, 10:27:38 pm »
Anyone know if you can fit a 33x12.5x15 on a stock Rallye wheel?  I have an 82' K10 with 32x11.5x15's on there now and wanted to go just a tad bigger and wider. Pic attached.
Offline enaberif
Re: What size tire will fit on Stick Rallye wheels?
« Reply #1 on: September 08, 2015, 10:36:14 pm »
Unless you got some form of a lift on that truck.. Putting 33s onto it may cause you some rubbing issues.
Offline roundhouse
« Reply #2 on: September 09, 2015, 08:02:30 am »
33s fit on ours with stock rally's and no lift
No rubbing at all
I don't mind a little rubbing anyway
If you're already running 32x11.5
A 33x12.5 is only 1/2 in taller and 1/4 wider on each side
« Last Edit: September 09, 2015, 08:04:02 am by roundhouse »
Offline 82FinkK10
« Reply #3 on: September 09, 2015, 08:40:52 am »
I was thinking the extra inch in height should be ok, just was not sure if the extra inch in width would fit on the stock rim?  Not sure how wide a tire will fit on that without having to get new rims.
Offline 82FinkK10
« Reply #4 on: September 09, 2015, 01:02:45 pm »
Roundhouse....will the 33x12.5''s fit on he stock rim?  Thanks!!!
Offline roundhouse
« Reply #5 on: September 09, 2015, 02:45:34 pm »
Yes
I have a picture somewhere
Was on last years website calendar
« Last Edit: September 09, 2015, 02:48:44 pm by roundhouse »
Offline Don5
« Reply #6 on: September 09, 2015, 03:16:51 pm »
Yes those tires will fit on stock Rallye wheels.
Offline roundhouse
« Reply #7 on: September 09, 2015, 03:25:02 pm »
33x12.50 BFG ATs
No lift
No rub
Offline 82FinkK10
« Reply #8 on: September 09, 2015, 04:01:35 pm »
Those look very nice!  I think I will do the 33's!! Thanks for the advice everyone.
« Reply #9 on: September 10, 2015, 08:30:16 am »
This might help you out Lift kit question for those with lift kits for those that want lift kits
my truck v3500
1. No lift 1991 v3500 crew with cummins
2. N/A
3. 285/75/16 (33/11.2/R16)
they rub on the drag link
my rims are only 6.5" wide so i dont know if that makes them "balloon" more and thats why they rub or what
Offline Peter S
« Reply #10 on: September 10, 2015, 02:47:20 pm »
Truck is stock height and there are no rubbing problems with 33 x 12.50 x 15 tires.
« Last Edit: January 03, 2016, 08:52:56 am by Peter S »
-Peter
1978 K10 stepside
