Author Topic: Won't stat...  (Read 3583 times)
Offline brandonblake1213
Won't stat...
« on: September 08, 2015, 11:04:52 pm »
My neighbor ( whos an 18 year old kid and just as I love with squarebodies as i am) has an 86 k5 that doesn't want to start any ideas or input is appreciated here's a list of things that have been checked into we're stumped
Fuel
Plugs
Wires
Changed caps bugs
The ignition module is good
Will crank but no fire
Sent from my LGLS770 using Tapatalk
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Won't stat...
« Reply #1 on: September 09, 2015, 05:12:31 am »
Three things to fire, spark, fuel, timing. If your getting spark and fuel at the cylinders, make sure plugs are in right location, and timing is close
 1986 Chevy K30(under repair)
Offline Willdabeast
  • Oldie but a Newbie
Re: Won't stat...
« Reply #2 on: September 09, 2015, 08:28:26 am »
If no spark try simple/cheap things first. Do you have a cheap test light? Key in Run position, hot both sides of all fuses? Good? check red wire on distributor, red wire along back of engine bay going to a black junction box above the distributor, see if connections good there I have seen problems there as well. Key in off position, Check fusible links/connection/wire at starter
P.S. Just in case I forgot to mention you can check Blade fuses in the fuse block, thats what the little metal tabs are on the back of them are for.
« Last Edit: September 09, 2015, 08:46:51 am by Willdabeast »
78 K20 sbc350 turbo 400 203NP w/lock-outs Current
Previous trucks, starting from first to present, 83 C20 350 700R - 85 C20 454 T400 - 86 K20 400 T400 NP 205 - 76 C10 454 T400 Heavy Half -82 C10 350 T350 - 84 C10 350 T350 Short bed - 03 Ram 5.7 Hemi
Re: Won't stat...
« Reply #3 on: September 10, 2015, 08:47:02 am »
like stated check the easy things first. make sure your getting 12v to the red wire on the distributor with the key on and when trying to start
did the truck just stall or one day not want to start?
theres also a pick-up coil under the distributor rotor and a icm (ignition control module) that will go bad and cause a no start
