Author Topic: Large hump or small hump?  (Read 9303 times)
Offline frotosride
    • WFO CONCEPTS
« on: September 10, 2015, 07:02:17 pm »
OK so I'm looking at new carpet and there are two options but I'm not sure. Large hump or small hump....how do I know. It's all original sheet metal so if there's a standard size hump for each transmission that would be great to know. 350/700r-4/NP208.
Offline enaberif
Re: Large hump or small hump?
« Reply #1 on: September 10, 2015, 07:21:50 pm »
You most likely have a high hump. If you take pictures we can tell for sure. Is it bolted in?
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: September 10, 2015, 07:41:57 pm »
Bolted in? The hump is not bolted in. I will try to get a shot real quick.
Offline frotosride
    • WFO CONCEPTS
« Reply #3 on: September 10, 2015, 07:51:37 pm »
Is it relative to height or width?
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #4 on: September 10, 2015, 07:52:08 pm »
Standards and 4x4 were mostly high hump, 2x4 autos were mostly low humps
 1986 Chevy K30(under repair)
Offline enaberif
« Reply #5 on: September 10, 2015, 08:35:21 pm »
Yup that is definitely a high hump.
« Reply #6 on: September 10, 2015, 08:38:02 pm »
I'll post this link too,
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11838.0
gives good visual of the humps(I believe 83 was the last year for bolt in humps)
Offline frotosride
    • WFO CONCEPTS
« Reply #7 on: September 12, 2015, 07:27:08 pm »
Fist time I've seen a small hump and I will definitely be able to tell the difference.
