Author Topic: No clue what these go to, help!!!!  (Read 3342 times)
Offline HAZARDOUSDUTY
« on: September 25, 2015, 10:11:23 am »
Ok, Truck info first, 1979 K10, Automatic TH350, 350 Engine had air at one time but I took it out and have heat only now. I'm in the progress of doing a frame off on this truck, pics can be seen on here, I have alot done since those pics though. My question to the group is I am currently rewiring the dash right now and i've ran into a couple of of wires i have no clue what they are for. pic#1 is a black wire with a white strip that looks like it runs behind the fuse box somewhere. Pic# 2 is a pink wire with a black stripe and runs into a clip that then runs into another clip, the pink wire is attached at the fuze block under a ign fuse spot. I guess what I need is 1. Do I need these wires and 2. if so what do they go to? Thank you for your help.
2010 Harley Davidson Wide Glide
2006 2500 Dodge Truck
1989 Chevy K5 Blazer
1979 K10 Chevy, 1974 Nova Hatchback
1931 Ford 5 Window
Re: No clue what these go to, help!!!!
« Reply #1 on: September 25, 2015, 10:15:06 am »
2nd pic
1931 Ford 5 Window
« Reply #2 on: September 27, 2015, 10:15:26 am »
I need more information like where a pic of where it is coming from.
Did you look in the Tech section where all the wiring diagrams are?
