Rear Drivelines, Drive Axles and Gearing
Rear end
Topic: Rear end (Read 9143 times)
bigblockstepside
Rear end
September 26, 2015, 09:31:34 am »
I have a 1977 c10 1/2 ton a was looking for information on what other factory rear end with posi traction could be swapped in with no problem any and all information would be greatly appreciated.
Sent from my SGH-T399N using Tapatalk
Re: Rear end
September 26, 2015, 10:00:26 am »
you want to swap rear ends or just the gears? a full swap would be cheaper i think. but what rear do you have now?(take a picture if you dont know)
bigblockstepside
Re: Rear end
September 26, 2015, 12:18:46 pm »
12 bolt half ton 5 lug WHOLE rear end would be fine
bigblockstepside
Re: Rear end
September 26, 2015, 12:20:10 pm »
Just looking for an easy swap from anything else that would bolt up
roundhouse
Re: Rear end
September 26, 2015, 01:01:03 pm »
Only thing that's a bolt in would be from another square body
Hard to find
The back axle is way too weak for a half ton
In the junkyards all the back axles are
Missing
Re: Rear end
September 27, 2015, 10:06:50 am »
anything from 73-81 C10's with a 12bolt is a bolt in, anything 78-87 C10's is a bolt in but you have to use a hybrid u-joint.
SkinnyG
Reducing resale value since 8-track days
Re: Rear end
September 27, 2015, 11:19:07 am »
I searched high and low for a decent 12-bolt for mine - they were all junk. I ended up coughing up the dough for a full-on rebuild of mine, with a TrueTrac diff.
Hard to find a decent anything that last rolled off the assembly line in 981.
The Crusty Chevy
: 1977 Silverado, shortboxed & dropped, potato-potato.
roundhouse
Re: Rear end
September 27, 2015, 10:48:58 pm »
14 bolts are easy to find
They are strong
10 and 12 bolts are typical weak GM cost cutting junk that had no business under a full size pickup
Rear end
