Author Topic: bad vibration  (Read 305307 times)
Offline philo_beddoe
  • 77 C-10
bad vibration
« on: October 17, 2015, 10:15:27 pm »
Surprised i couldent find some old posts on this.  2wd c10, starting to notice a pulsating vibration at about 45-50 mph.  Feel it right through the seats, not the steering column.  Most likely u joints?? How do you check or test them?
« Last Edit: January 09, 2016, 02:56:41 pm by Irish_Alley »
Offline 85ckaz
Re: Pulsating vibration at 50
« Reply #1 on: October 18, 2015, 01:57:52 pm »
I replaced the transmission mount in my K20 to eliminate the same issue. To check U joints just push on the drive shaft and you should have no movement.  I would also check the pinion gear bearings/ rear diff yoke for movement. They should be tight. If there is slop in anything it needs to be repaired/ replaced.
  • 77 C-10
« Reply #2 on: October 19, 2015, 08:06:55 am »
I'm on it! Thanks!
  • 77 C-10
« Reply #3 on: October 20, 2015, 07:32:44 am »
New tires and factory rims, but i'll check the weights anyway.  It is not "shuddering" like a bad unbalanced wheel, more of a steady vibrate, hardly pulsating i guess, seems to smooth out near 60 mph.  I tried to move driveshaft, tight as a drum.
  • 77 C-10
« Reply #4 on: October 20, 2015, 07:37:16 am »
....oh and yes, one piece shaft,  as far as being a new problem.,, we'll im just now noticing.  I guess i'll let it go for now.  My mechanic is a chevy guy, (i only use him when a garage is needed),  im getting new exh manifolds put on soon, i'll have him take a look.
  • 77 C-10
« Reply #5 on: October 22, 2015, 10:15:28 pm »
Not sure what you mean "out of phase"
  • 77 C-10
« Reply #6 on: October 27, 2015, 05:26:14 pm »
That makes good sense., but i have a one piece shaft.
  • 77 C-10
« Reply #7 on: October 27, 2015, 05:29:21 pm »
....or does it matter in terms of speaking out of phase?
  • 77 C-10
« Reply #8 on: October 28, 2015, 09:50:29 am »
I will take a look.  It seem to let up when i let off the gas. Does this make sense?
« Reply #9 on: October 28, 2015, 10:41:51 am »
Yes. I know with my crew cab I had a vibration. I replaced the carrier bearing and my shaft was out of phase fixed both them and the vibration under throttle went away.
  • 77 C-10
« Reply #10 on: October 28, 2015, 08:39:12 pm »
Carrier bearing? Ok, where is it and what does it look like?  I have not delved into that area too much.
« Reply #11 on: October 28, 2015, 09:02:15 pm »
The carrier bearing will be in the driveshaft.
  • 77 C-10
« Reply #12 on: October 28, 2015, 09:30:08 pm »
Ok, will have a look, thanks.
« Reply #13 on: October 28, 2015, 09:36:07 pm »
Carrier bearing won't be found on your truck. Only 2+ piece drive shafts. It keeps the driveshaft in line. There's a physical limit to how long/thick a driveshaft can be. So they have to split it up in a couple different sections. Fist section will have the driveshaft bolted to the transmission or transfer case. Then a few feet down the carrier bearing attaches to the frame to keep it in line then you have male splines on the end of the first shaft and a female slip yoke drive shaft that will bolt to the rear
  • 77 C-10
« Reply #14 on: October 28, 2015, 09:52:02 pm »
Ok, appreciate the feedback. Maybe it's the flux capacitor...lol.   I will get under there and check correct phase first, check ujoints again, etc.
