Author Topic: bad vibration  (Read 305417 times)
Offline philo_beddoe
  • 77 C-10
Re: bad vibration
« Reply #120 on: January 25, 2016, 09:16:15 pm »
Ok i'll ask,,,whats a cylinder power balance test?
Vile, your pretty savy with these trucks, but i think this one might even stump you.  (Or maybe im just using reverse psychology to get you to invite me over to fix this cursed problem).
  • 77 C-10
bad vibration
« Reply #121 on: January 25, 2016, 09:26:05 pm »
I'm gonna try to reread this whole thing and put my thinking cap on. :o I wish I could come over and look at it.
Capt. Swampy..I would LOVE for you and any of the "usual suspects" on this forum to take a crack at this. If i were wealthy, i would fly some of you out here and we would have a 77 Chevy diagnostics party.
I would pay the first guy who nailed this thing a thick stack of cash!!
If it aint the balancer then its got to be some thing internal, and im not paying much more than 200 bucks to end this madness.
I'll let the block crack itself open and burn first. Then get a new 350 crate engine!
I am honstly getting steamed as i type this.
« Last Edit: January 25, 2016, 09:28:33 pm by philo_beddoe »
Offline Rattler12
  • Old Geezer
Re: bad vibration
« Reply #122 on: January 25, 2016, 10:48:56 pm »
Have you ruled out the water pump?
83 C-10 shorty 454, 5spd, 3:73 posi
  • 77 C-10
bad vibration
« Reply #123 on: January 26, 2016, 07:47:35 am »
Water pump? Doh!!!  Not entirely, but it's quiet and my temp is good, and the pulley on it looks straight and tight.
Actually now that i remember, i did unhook all belts and ran engine, still shudders/vibrates.
« Last Edit: January 26, 2016, 07:52:13 am by philo_beddoe »
  • 77 C-10
bad vibration
« Reply #124 on: January 26, 2016, 05:01:07 pm »
The mechanic didnt come up with much, except that it looks like i have a 350 and not a 305, and that i need to match up the right harmonic balancer with the right flexplate. I have a 383 stamped on my block, what does that mean?
Anyway,,,,so why didnt it shudder before?!!! I never noticed it before!!!! I'm not convinced.
I cant believe i have to drive around with this problem until i can save up enough for a new crate engine. I never thought it would come to this.
Re: bad vibration
« Reply #125 on: January 26, 2016, 05:21:04 pm »
Behind the alternator there is a series of numbers stamped on the block.  Lets start there by determining what you have
  • 77 C-10
Re: bad vibration
« Reply #126 on: January 26, 2016, 05:26:17 pm »
Ok, i will check and post asap.  I also need encouragement, at the end of my rope!
Re: bad vibration
« Reply #127 on: January 26, 2016, 05:40:37 pm »
We'll all try to help.  I can tell you a story but would only be a downer so I will keep it to myself...
Was the engine ever ran with the torque converter disconnected?
  • 77 C-10
Re: bad vibration
« Reply #128 on: January 26, 2016, 05:47:05 pm »
Here it is! What do you make of it??
  • 77 C-10
Re: bad vibration
« Reply #129 on: January 26, 2016, 05:51:03 pm »
I dont believe it was ran with the t converter disconnected.
Re: bad vibration
« Reply #130 on: January 26, 2016, 05:51:24 pm »
DNL is a 1979 305... Looks like your mechanic may not know everything so you have a prayer
Re: bad vibration
« Reply #131 on: January 26, 2016, 05:53:10 pm »
Look carefully at the smaller #'s.  They should contain the last numbers of the trucks VIN if it is original to the truck
Re: bad vibration
« Reply #132 on: January 26, 2016, 05:54:25 pm »
  • 77 C-10
Re: bad vibration
« Reply #133 on: January 26, 2016, 06:02:55 pm »
I cant match this up with anything!
  • 77 C-10
Re: bad vibration
« Reply #134 on: January 26, 2016, 06:03:19 pm »
Ok, hang on.
