Author Topic: Gear ratio question  (Read 5433 times)
Offline BBC78K20
Gear ratio question
« on: October 18, 2015, 01:38:37 pm »
Hey guys I'm new to the forum and figured I'd ask a question that I can't quite get an answer to. I plan on pulling an enclosed car trailer weighing around 7-8k. I have 37" tires and currently have 4.10s. Its a project for now just wondering if I should go 4.56 or 4.88. Opinions?
1978 K20 on 37's
Mild built 454
4l80e trans
NP241 tcase
Re: Gear ratio question
« Reply #1 on: October 18, 2015, 04:34:11 pm »
ive done some towing with my 79 k20 350/sm465 with 4.10s and 38s. i didnt have a problem. now i didnt pull real heavy loads occasional car trailer and other trailers. one good thing if i needed it i could use 1st gear to get going. and depending on where youre hauling (mountains or planes) would effect the ratio choice also. now in my 91 crew cab with a cummins and 4l80e with 4.10s ive hauled a heavy dump trailer full of trash. the total weight was 12840 lbs. my best estimate of the truck is 7500. i only had 33s, with 37s she would of been a dog even with the cummins. i would at least go with the 4.56. though it might hurt your mpgs but your rpms will only rise a couple hundred more than what they are now at cruising speeds but the less effort when taking off might counter that
Offline BBC78K20
« Reply #2 on: October 18, 2015, 06:24:27 pm »
Ill be pulling through some hills for sure. I bought 4.88's for the front a while back but wasn't sure. With overdrive it might not make much of a difference between the two, not sure. But thanks for the reply!
1978 K20 on 37's
Mild built 454
4l80e trans
NP241 tcase
« Reply #3 on: October 18, 2015, 06:30:38 pm »
between the 4.88s and the 4.56 youre only talking about 100 rpms difference. if you already got the front i would get the rear put in and try it out without doing the front that way you can at least sell or return the front
