Author Topic: frame swap  (Read 4948 times)
Offline Ace1984
frame swap
« on: December 27, 2004, 12:35:00 am »
I was wanting to know if a 1977 C-10 body would fit on a 1986 K-20 frame? And also the body is GMC and the frame is Chevy....
Offline roundedline
Re: frame swap
« Reply #1 on: December 27, 2004, 11:07:00 am »
Yes, they will swap.  There might be issuse if you have a manual trans though or if the K10 requires a High hump.  You need to  use the body bushings that are specific to the frame.  The only difference in GMC vs Chevy is the badging, they are identical otherwise.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
