Author Topic: Replacing floor pans, seat & belts  (Read 33285 times)
Offline philo_beddoe
  • 77 C-10
Re: Replacing floor pans, seat & belts
« Reply #15 on: November 14, 2015, 07:08:52 pm »
I agree with joec... RUST SUCKS!  I dont tolerate it. Just changed out a rusted battery tray.   Thats a nice project truck, stay with it.
  • 77 C-10
« Reply #16 on: November 14, 2015, 10:07:10 pm »
Oh, and new factory oem seatbelts do not exist. Nor do aftermarket lookalikes. Some 73-87 parts they just cant produce. My original belts were so bad they deteriorated and crumbled apart. Had to get black aftermkt. But they do install fine.
Offline Jrgunn5150
« Reply #17 on: November 25, 2015, 10:31:44 pm »
I also need that little lip the weather strip attaches too... What body panel is it a part of?
1979 C10 Stepside 400/TH350/12 Bolt. 3.08's
1975 F100 4x4 390/C6/37's 4.88's
2006 Trailblazer 5.3/4l60e/4.56's 33's
2011 Ford Edge..... I have no idea, I just drive it to work lol
  • 77 C-10
« Reply #18 on: December 04, 2015, 10:01:15 pm »
Isnt that actually part of the cab itself, that might be a challenge.  Perhaps check the three letter catalog we dont mention on this site.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #19 on: December 05, 2015, 06:13:28 am »
If your talking about the lip along the bottom of the door area, that is part of the outer rocker. It also looks like you need a section of the inner rocker( inner rocker is actually part of the outer floor)
 1986 Chevy K30(under repair)
Offline CA Big Red
    • Big Red Squarebody
« Reply #20 on: February 06, 2016, 10:25:43 pm »
The floors are in! Lizardskin is on. Things are looking good.
"You don't know what you don't know."
1978 Scottsdale Stepside
383 w/ 4" lift & 35" BFG
Offline CA Big Red
« Reply #21 on: February 06, 2016, 10:26:52 pm »
I painted the stick shift and steering column while I waited for the lizardskin to dry.
Offline LTZ C20
« Reply #22 on: February 07, 2016, 12:26:04 am »
That looks really nice, I'm impressed.
LTZ Cheyenne C20
Offline CA Big Red
« Reply #23 on: February 07, 2016, 10:47:54 am »
Thanks LTZ. I'm impressed that the cab already sounds different when you're in there with the doors closed. Like it might actually be working. I haven't fired it up yet to hear the difference. I need to put the rubber floor liner back down, install the seat, etc.
Offline LTZ C20
« Reply #24 on: February 07, 2016, 01:37:09 pm »
Yea I'm sure it does.
LTZ Cheyenne C20
Offline sbailey05
« Reply #25 on: March 15, 2016, 09:47:37 pm »
Which lizardskin product did you use? I'm actually thinking about doing this EXACT same project as I have quite a bit of rust under there and I didn't remember it being that bad. Yours came out quite a bit better than I was expecting. Are you leaving the liner like that or putting the original carper or flooring back over it? I believe I'll need new carpet though cause mine is pretty shot.
Offline OldGray
  • Ne'er-do-well
« Reply #26 on: March 15, 2016, 11:33:28 pm »
I ran across a cheap alternative product for sound deadening and used it on my doors and was very happy with the results.
PEEL & SEAL aluminum flashing.
http://www.lowes.com/pd_154017-81326-PS625___?Ntt=peel+and+seal&UserSearch=peel+and+seal&productId=1018733
1979 Chevrolet Bonanza / 305 / LWB
Offline sbailey05
« Reply #27 on: March 16, 2016, 12:57:13 pm »
Thanks! I'm for sure going to do this in the next week! Just gotta order some replacement metal to fix the rusty floor first.
Offline CA Big Red
« Reply #28 on: March 29, 2016, 10:34:48 pm »
The sound deadening has been an improvement, but not as quiet of a ride as I had hoped. Worth it? I can't give it an enthusiastic yes. However, I'll have a better sense of things when I get this new mat installed and holes covered in the high hump. I also still need to finish my AC and put the dash back together. Then I think we'll be able to compare apples to apples. Bottom line, a cell phone call rolling at 65mph is really not fair to the person on the other end.
Offline CA Big Red
« Reply #29 on: March 29, 2016, 10:36:25 pm »
I did get the new seat belts and seat cover installed. Really like the way the seat turned out. Very disappointed in the retro belts USA.   Crazy that they send that product out like that.
