Author Topic: Read end ratio question for 700r4 swap  (Read 6320 times)
Offline aaronboss221
« on: October 28, 2015, 01:32:44 pm »
Hello from Cookeville, TN. I have a 1986 c10 350 th350 combo with 2.73 gears currently running 255/70/15 tires. The motor has no upgrades done to it. I bought a 700r4 and was going to swap it out for mine. Just a little unclear on gear ratios and how it would effect my driving with the gears I have and tire size. I do have opportunity to buy a posi rear end with 3.73 gears off a local guy. Just wondering what I should do?
Sent from my VS986 using Tapatalk
Offline rich weyand
Re: Read end ratio question for 700r4 swap
« Reply #1 on: October 28, 2015, 03:12:13 pm »
Don't put a 700R4 on 2.73:1 gears.  Your final in OD will be 2.0:1, which is ridiculous.  700R4s don't like to be lugged.
The 3.73:1 rear end with posi is perfect for the 700R4.  Do it.
« Reply #2 on: October 28, 2015, 07:32:31 pm »
That's what I was thinking but wasn't sure cause I had bigger tires on it. I appreciate it!
Offline rich weyand
« Reply #3 on: October 28, 2015, 07:39:57 pm »
Bigger tires lowers your rear end ratio further.  Think about it.  Even more important to get the 3.73.  Also, you'll like the posi.
Offline Captain Swampy
  • Wisconsin
« Reply #4 on: October 29, 2015, 09:38:44 pm »
Search for a gear ratio calculator, then you can play with tire size and gear ratio to get what you want. Bigger tires on the same gear = a taller (numerically lower) rear end ratio. The 3.73 would be the right direction, you could change tire size to work with those gears if it isn't exactly what you want.
