Author Topic: 1987 4x4 r-10 ?  (Read 4010 times)
Offline gutts
1987 4x4 r-10 ?
« on: October 28, 2015, 10:22:08 pm »
Hello
 I have a mongrel truck that I believe is a 1987 r-10. 4x4 6' bed
   I am confused about what y pipe to get
  The one that rusted off had the o2 sensor up close to the manifold
   Can anyone give me a part number ? There is no other exhaust pieces to match up to in the truck now . I just need the right y pipe .
   Anyone please ?
Offline rich weyand
Re: 1987 4x4 r-10 ?
« Reply #1 on: October 29, 2015, 01:28:01 am »
If it's a 4x4, it's a V-10, not an R-10, which is 2WD.
Which engine does it have?
You can select "Product Options" on this page to select "V10" and either "V6" or "V8" to get the right product.  Note you may have to drill out the sensor port.  I guess they put the bung on the pipe, but don't drill it out, so it is the same part whether you want to install the sensor for the computer TBI or go carbed without the sensor.
http://www.carid.com/1987-chevy-ck-pickup-exhaust-parts/walker-exhaust-pipe-46781486.html
Offline gutts
Re: 1987 4x4 r-10 ?
« Reply #2 on: October 29, 2015, 06:42:57 am »
Thank you
  I've no paper work on the frame .the cab is a 1979
  I get so confused , v-10 not r-10
   Thank you
    I have got remember it is a V !
Offline Captain Swampy
  • Wisconsin
Re: 1987 4x4 r-10 ?
« Reply #3 on: October 29, 2015, 09:22:39 pm »
I've seen a couple different style manifolds, but they all had the o2 sensor in the manifold not the y pipe. Is the truck TBI or carbureted? 87 V10 should be TBI.
Offline gutts
Re: 1987 4x4 r-10 ?
« Reply #4 on: October 30, 2015, 11:08:22 pm »
The truck had a o2 sensor close to manifold on the y pipe . It probably was changed before I got it . The y pipe I ordered has the o2 down stream of the "y" pieces . I will probably put it up high so I don't have to cut the wires .
