Interior & Equipment
Steering Columns
Tilt steering wheel
Topic: Tilt steering wheel (Read 9517 times)
Will84K10
Tilt steering wheel
October 30, 2015, 07:36:33 pm »
1984 K10 with tilt steering wheel. When I push upwards on the bottom of the steering wheel it has a lot of play/slop . Is this the dreaded 4 bolts without locktite issue? Figured I'd ask before starting the whole steering column disassembly. Thanks.
bd
Re: Tilt steering wheel
October 30, 2015, 08:11:41 pm »
If the column remains rigid in the dash and only the steering wheel and upper column housing are loose, then yes.
How-To: Fixing a Sloppy GM Tilt Column
Will84K10
October 30, 2015, 09:30:42 pm »
Ok I appreciate the help and link. is this usually a multiple hour job?
bd
October 31, 2015, 02:06:26 pm »
Yes. More so, the first time through. The Torx drivers and three special tools (steering wheel puller, lock plate depressor, and pivot pin remover) make the job considerably easier.
roundhouse
November 01, 2015, 10:26:47 am »
Link doesn't work for me
bd
November 01, 2015, 03:13:26 pm »
Quote from: roundhouse on November 01, 2015, 10:26:47 am
Might have something to do with your phone(?). It Links to the Technical Pages thread by the same name.
Will84K10
November 04, 2015, 10:05:44 pm »
So I was able to tear everything down and tighten the 4 bolts but once i put everything together its seems like something got messed up because my gear shifter is extremely tight. any ideas? thanks
Steering Columns
Tilt steering wheel
