Author Topic: Need rubber gromets.  (Read 17382 times)
Offline philo_beddoe
  • 77 C-10
« on: November 04, 2015, 10:02:23 pm »
Is it possible to purchse those small black rubber gromets for this style mirror? I hope so!
« Last Edit: November 04, 2015, 10:06:04 pm by philobeddoe »
Offline timthescarrd
Re: Need rubber gromets.
« Reply #1 on: November 04, 2015, 10:20:23 pm »
After searching several stores and asking Chris who owns this site, I finally found some on ebay
http://www.ebay.com/itm/2-GM-Truck-Mirror-Cover-Grommets-Chevy-GMC-1973-87-Trim-77-78-79-80-81-82-85-87-/311339856696
  • 77 C-10
« Reply #2 on: November 04, 2015, 10:24:55 pm »
Thanks! I need all four, but i'll start with those two.
Offline LTZ C20
« Reply #3 on: November 05, 2015, 01:10:50 am »
Just an FYI, those are nothing special, plain old rubber grommets. You can get them at auto parts stores in the "help!" section in the grommet assortment pack, online, orchard supply hardware has a large supply of odd things like that,  or places like summit racing sell kits with all different sizes. They are just sheet metal grommets.
« Last Edit: November 05, 2015, 01:12:45 am by LTZ C20 »
LTZ Cheyenne C20
  • 77 C-10
« Reply #4 on: November 05, 2015, 08:44:14 pm »
Thanks!!  I did however find some OEM ones at a dealer.  NOS, they were three bucks each.  Got 4.
  • 77 C-10
« Reply #5 on: November 05, 2015, 08:45:43 pm »
But officially they are discontinued, of course.
Offline LTZ C20
« Reply #6 on: November 05, 2015, 08:47:15 pm »
Well that's good, for future reference tho, I would just go to one of the places I suggested. They are not one of those things I would consider needing to be factory original replacements.
LTZ Cheyenne C20
  • 77 C-10
« Reply #7 on: November 05, 2015, 09:57:52 pm »
Hey LTZ, i just realized your the one with the new custom mirrors.  Well, i guess you know where to get grommets then.   Hey, do you think its possible to go to those smaller mirrors i posted in your other post? It wont be for a few years anyway when i do a full body resto.
« Reply #8 on: November 05, 2015, 10:11:05 pm »
i wonder how much you could slide the original mirrors out with the modified tube. ltz how did you get the mirror off without breaking the glass?
Offline LTZ C20
« Reply #9 on: November 05, 2015, 10:26:13 pm »
Hahaha, now your catching on.  So what are you asking with the smaller mirrors??
Are you asking if you can put the mirrors I took off my truck onto your truck? What mirrors do you currently have?
LTZ Cheyenne C20
Offline LTZ C20
« Reply #10 on: November 05, 2015, 10:28:10 pm »
Whaaa? You mean slide out the smaller mirrors I took off?? I don't know what's holding them together, never had 1 of those mirror heads apart? Are you referring to the arms on my new mirrors as the modified ones?
As for the glass, VERY CAREFULLY. I banged the mirror against the concrete till if fell out. Ok just kidding. The rubber seal is U shaped. I rolled the seal on one side toward the middle of the glass until it popped out, then with the exposed piece, I slowly went along and rolled the seal toward the glass with 1 hand and pulled up and away with the other hand. About 3/4's of the way around, 1 mirror just popped out. The other got 3/4's of it out and then just lightly pulled on the mirror out and way from the housing and it popped out. I found the mirror glass it self is double sided, so it didn't matter which way I put it back in, both sides are mirrored but I put it back with the same side facing out as they came.
« Last Edit: November 05, 2015, 10:34:09 pm by LTZ C20 »
LTZ Cheyenne C20
« Reply #11 on: November 05, 2015, 10:38:47 pm »
yeah something like combining your setup with the oem one.
Offline LTZ C20
« Reply #12 on: November 06, 2015, 01:43:34 am »
Ok now I'm really confused. My setup and the oem one, my setup is 2 oem setups mashed together.
LTZ Cheyenne C20
  • 77 C-10
« Reply #13 on: November 06, 2015, 06:18:32 am »
As far as me...this is what i have now.
And this is what i'd like in the future when i do a full body restoration.
  • 77 C-10
« Reply #14 on: November 06, 2015, 06:19:12 am »
Both are factory offered. I am just wondering if the conversion is possible without changing doors.
