Author Topic: Truck stuck in neutral  (Read 14448 times)
Offline Sprinkler-Man
  • 80 GMC Sierra Classic 4x4
Re: Truck stuck in neutral
« Reply #15 on: November 12, 2015, 07:54:36 pm »
It doesn't move with the transmission in park so I'm guessing it's the transmission too.   I hope it's not the converter. Just put in a new 2500 stall.
« Reply #16 on: November 13, 2015, 12:46:37 am »
well got some bad news. even if its something in the trans the converter is still contaminated and should be replaced.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #17 on: November 13, 2015, 02:43:40 pm »
Agreed, if you want any kind of warranty on new trans, you need new tc
That being said, I have seen new tc's go bad almost immediatly- something that could mean warranty replacement
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
« Reply #18 on: November 13, 2015, 02:59:08 pm »
i was thinking the same thing. if you still have a warranty on that tc you might be able to get a replacement
« Reply #19 on: November 14, 2015, 07:18:25 am »
How can you tell if it is the TC?  I have my old one still so I could put that one back in but that is a lot of work just for a test.
« Reply #20 on: November 14, 2015, 02:58:43 pm »
im not sure if you can pin point if its the tc or trans. i dont see the harm in putting your old one back in since it should be scrapped anyway due to it being contaminated. i dont know if you will see any difference in if the trans works or not
« Reply #21 on: November 14, 2015, 03:59:44 pm »
I guess we should ask why the TC was changed in the first place. if you just wanted a higher stall, and the original was fine, then popping it back in may show the new TC is at fault if the truck moves-which means check warranty on TC
 a transmission rebuild should really be considered even if it ends up being the TC, so many fine particles going through the tranny is not good
the odds of an auto just failing with no warning of slipping or anything tend to be pretty slim, although now that I say that; it isn't really all that uncommon either, it is just less likely
« Reply #22 on: November 14, 2015, 04:57:17 pm »
ive heard of tcs going bad shortly after install. and most of refurbished but the problem is with that afaik its only a visual inspection of the internal parts and if it looks bad they will replace it
« Reply #23 on: November 14, 2015, 07:07:29 pm »
Well it is not the transfer case.  I am going to drain the fluid from the transmission and see if there is any metal in it and start from there.  I put in a new 2500 stall because I rebuilt a 350 and the power curve is in a higher RPM range then stock.  I will have the trans rebuilt over winter and start again in spring....I only have about 10 miles on the new engine and wanted to get some miles on it before the snow flies...bummer
« Reply #24 on: November 14, 2015, 08:50:14 pm »
so you put about 10 miles on this 2500 stall TC?
« Reply #25 on: November 16, 2015, 02:46:59 pm »
Yes, that's it.
« Reply #26 on: November 16, 2015, 02:58:57 pm »
yeah sounds like the stall is the problem.
