Author Topic: Heads  (Read 16334 times)
Offline st3vomettler
Re: Heads
« Reply #15 on: November 10, 2015, 07:19:32 pm »
It's a Autozone brand carb that I bought for my old 77 350.
77 c10 Silverado 350 nv3500 5spd
Re: Heads
« Reply #16 on: November 10, 2015, 07:21:34 pm »
I have the adaptor to run the edelbrock carb.
Offline SkinnyG
  • Reducing resale value since 8-track days
Re: Heads
« Reply #17 on: November 10, 2015, 09:44:00 pm »
You would probably have better performance with the Q-jet and without the adapter, but that's just my opinion.
If the Q-jet sucks, swap carbs and use the adapter.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Re: Heads
« Reply #18 on: November 10, 2015, 10:09:53 pm »
It works on it but for some reason the back two barrels want kick in like it's saposed to and I rebuilt it to
Offline SkinnyG
Re: Heads
« Reply #19 on: November 10, 2015, 11:43:21 pm »
Just learn how to tune it (grin).  Lots of stuff online, and excellent books on the Q-jet (Cliff Ruggles book is good).  A properly setup Q-Jet is an awesome thing, but few people want to learn them well enough to set them up properly.
Re: Heads
« Reply #20 on: November 11, 2015, 06:07:33 am »
Ok but it's not a qjet its a autoline carb from autozone
Offline blazer74
Re: Heads
« Reply #21 on: November 11, 2015, 07:08:28 am »
Autoline is a rebuilder, could still be  a Qjet.
Offline Dan75k20
Re: Heads
« Reply #22 on: November 11, 2015, 10:03:44 am »
Snap a photo of the carb. 305 ho heads were on z28 camaros in the 80s alot of circle track guys run them on 350s
Re: Heads
« Reply #23 on: November 11, 2015, 11:45:17 am »
Ok I will When I get home and Would you happen to now what causes it to hesitate?
Offline blazer74
Re: Heads
« Reply #24 on: November 11, 2015, 06:53:38 pm »
^this.       Lots of variables, depending on when.
History of carb, did it run good before.
Off idle stumble, cruise stumble, ?
Re: Heads
« Reply #25 on: November 11, 2015, 07:09:57 pm »
Off idle and it done it since I bought it for my old 350
Offline enaberif
Re: Heads
« Reply #26 on: November 11, 2015, 07:12:40 pm »
Any off the shelf carb you buy for ANY vehicle is NEVER a bolt on and go setup. You will need to tweak and tune that carb to run right.
Re: Heads
« Reply #27 on: November 11, 2015, 07:20:39 pm »
I've tried and tried but I still can't get it to run right I have even rebuilt it but when I put my edelbrock 1406 carb on it it ran great but it keeps flooding out
Offline enaberif
Re: Heads
« Reply #28 on: November 11, 2015, 08:45:26 pm »
1406 needs a fuel regulator or you'll flood it.
Offline blazer74
Re: Heads
« Reply #29 on: November 11, 2015, 11:46:58 pm »
Hard to say what the rebuilder did to it. They try to make them generic so they will fit more applications.
Stumble off idle could be lean or rich. Improper pump shot, over rich or lean idle circuit. If you can disconnect the acc pump linkage and blip the throttle in neutral/park and see if the stumble gets better or worse. Watch the linkage doesn't get hung up tho.,
