Author Topic: Heads  (Read 16333 times)
Offline 1979mmx350
Re: Heads
« Reply #30 on: November 12, 2015, 02:09:49 am »
Ok I'll go with the stock intake for now but should I use the spread bore carb that's already on it or a edelbrock 600cfm that I have?
I threw on an Edelbrock 1406 last week and it was running cherry til I blew a rod earlier today. Actually, could any of you recommend a solid cam replacement?
« Last Edit: November 12, 2015, 02:11:33 am by 1979mmx350 »
1979 C10 Scottsdale 5.7L 4spd
Offline st3vomettler
Re: Heads
« Reply #31 on: November 12, 2015, 06:04:03 am »
Ok any suggestion on what the fuel pressure should be for it
77 c10 Silverado 350 nv3500 5spd
Offline enaberif
Re: Heads
« Reply #32 on: November 12, 2015, 05:49:41 pm »
4-5psi MAX anything more and you'll just flood the carb.
depending on what you want 12-300-4 is highly regarded if you want something for torque.
Re: Heads
« Reply #33 on: November 12, 2015, 06:25:53 pm »
Ok thank you would anyone happen to now what the valve lash is saposed to be set for
Re: Heads
« Reply #34 on: November 14, 2015, 06:51:17 pm »
It is a qjet and the number on it is 17058213 2457 bjb
Offline 1979mmx350
Re: Heads
« Reply #35 on: November 14, 2015, 10:54:32 pm »
Whoops meant to say crank actually.
