Welcome
New guy
Topic: New guy (Read 6479 times)
Goodtogomatt
New guy
November 13, 2015, 09:23:11 am »
Hello out there new to the sight. I'm having an issue with my 84 k10. I'm no mechanic, but I am mechanically inclined. I believe the issue is in the carb, but could be wrong. When I drop down in gear the idle drops very low. When I first step on the gas it will start to choke and some times die. When I get down the road its fine. If I stop it will sputter a bit when taking off but not as bad as when I first put it into gear. Any help would be appreciated its an eddelbrock 1407 on a 350. Thank you and God bless.
Last Edit: November 13, 2015, 09:49:57 am by Goodtogomatt
84 k10 swb
zieg85
Re: Carb issue
November 13, 2015, 09:28:27 am »
Welcome to the site from west central IL
Last Edit: November 13, 2015, 09:36:55 am by zieg85
timthescarrd
Re: New guy
November 13, 2015, 11:02:38 am »
Welcome from NV.
It's normal for the idle speed to drop when you go into gear. I'm assuming it's an auto. Your Idle speed should be around 800RPM in Park/Neutral and then drop down to around 550RPM in Drive/Reverse. Also check your timing.
The edelbrock 1407 is a 750cfm carb which is pretty big for a 350.
A little history on the truck and the issue will g a long ways towards troubleshooting. Is the truck new to you? Has this issue been going on for awhile or is it new? Has anything on the truck changed recently? Is the motor mostly stock or built up? what Mods/Changes are there? What transmission does it have?
Goodtogomatt
Re: New guy
November 13, 2015, 11:27:31 am »
I just bought the truck about a month and a half ago. It's a 3 speed automatic and I'd say it's pretty much stock. It's had this issue since I bought it. It's the last issue I need to fix to call it mechanically sound. I've replace the drivers side gas tank and fuel sending unit, flushed radiator, changed hoses, changed all fluids, replaced drivers side freeze plug behind motor mount, thermostat and housing and belt.
84 k10 swb
Re: New guy
November 15, 2015, 05:09:04 pm »
welcome from maryland
Jason S
Re: New guy
November 15, 2015, 07:38:26 pm »
Howdy from Kansas!
philo_beddoe
77 C-10
Re: New guy
November 15, 2015, 09:52:51 pm »
Welcome from MA. "I dont think were in kansas anymore". Sorry, had to say that.
frotosride
Re: New guy
November 21, 2015, 07:20:51 pm »
Welcome from Georgia. Something that may get you more help is posting this in then Engine/Drive train section. One because its the appropriate place for it and two because not everyone checks all the new members post.
Tazman
Re: New guy
November 22, 2015, 02:04:05 pm »
Welcome from AZ.
God BLESS AMERICA
Welcome
New guy
