Author Topic: Carb issue?  (Read 5592 times)
Offline Goodtogomatt
Carb issue?
« on: November 13, 2015, 09:30:06 am »
Hello out there new to the sight. I'm having an issue with my 84 k10. I'm no mechanic, but I am mechanically inclined. I believe the issue is in the carb, but could be wrong. When I drop down in gear the idle drops very low. When I first step on the gas it will start to choke and some times die. When I get down the road its fine. If I stop it will sputter a bit when taking off but not as bad as when I first put it into gear. Any help would be appreciated its an eddelbrock 1407 on a 350. Thank you and God bless.
84 k10 swb
Re: Carb issue?
« Reply #1 on: November 13, 2015, 09:35:00 am »
Check for vacuum leaks, from cracked hoses.  It also could be an accelerator pump on the carb.  See if at idle there is gas visibly dripping while looking in the carb.
Re: Carb issue?
« Reply #2 on: November 13, 2015, 09:57:21 am »
Couldn't find any vaccum leaks and can't see any gas dripping.
84 k10 swb
Offline 1979mmx350
Re: Carb issue?
« Reply #3 on: November 13, 2015, 01:53:26 pm »
Sounds like you need to adjust the screws on your carburetor. There are YouTube videos which can show you how.
1979 C10 Scottsdale 5.7L 4spd
Re: Carb issue?
« Reply #4 on: November 13, 2015, 03:02:26 pm »
whats your timing set at?  make sure you have no vacuum leaks and then try and tune the carb
Re: Carb issue?
« Reply #5 on: November 13, 2015, 05:58:00 pm »
Thanks for the help. Tuned the carb today its definitely better I'm going to straighten out the timing this week and change the plugs.
84 k10 swb
Offline rich weyand
Re: Carb issue?
« Reply #6 on: November 14, 2015, 11:07:01 am »
AC Delco R45TS or Autolite 24 spark plugs.
Check out my new ignition timing thread.  It's a sticky at the top of the Engine/Drivetrain category:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32085.0
Offline TJ Kollmeyer
Re: Carb issue?
« Reply #7 on: November 14, 2015, 11:01:30 pm »
i had this same exact problem on my holley 600 carb on my '83 k10. on mine and what it sounds like on yours is that the floats are sticking inside the carb. if it wont stay idling healthily try tapping the fuel bowls with a hammer and see if it has any effect. if it does effect it, buy a rebuild/trick kit and change out the pin and seat assembly. hope this helps
