Author Topic: adapter plate bolts - to transmission - where buy new ones ?  (Read 7338 times)
Offline koolray09
« on: November 14, 2015, 09:39:57 am »
I have a turbo 350 with np230 and requisite adapter plate.   Four bolts hold the adapter plate to the transmission.
these bolts are special in that they have - what looks like - a small shoulder where the threads meet the underside of the bolt head.
there is a matching circular indention in the adapter plate to match.
Where do I go to buy those bolts new ?
Offline werewolfx13
Re: adapter plate bolts - to transmission - where buy new ones ?
« Reply #1 on: November 14, 2015, 11:04:54 pm »
Might try a dealership, I used ordinary grade 8 bolts on my 350/203 combo.
Chris
'83 Chevy c10 Silverado SWB
Offline koolray09
« Reply #2 on: November 15, 2015, 08:01:39 am »
Dealership was my first call.  No luck.
« Reply #3 on: November 26, 2015, 12:22:35 pm »
Any hardware store will have bolts to fit your threads, & length. Grade 8 will be the best bet. Clean the holes out with some brake clean, maybe compressed air if you have a compressor. Use blue lock tight on the new bolts.
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #4 on: November 26, 2015, 12:53:23 pm »
Fastenal carries all types of bolts and such.
Offline koolray09
« Reply #5 on: November 26, 2015, 04:26:41 pm »
As it turns out...what I thought was a machined surface that looked like an o-ring, turned out to be an actual o-ring.  It is a sealing washer. AS you know, the adapter plate has a gasket where it bolts to the NP203 xfer case.  Those bolts, if not sealed will allow fluid from the xfer case to leak.  Turns out, nothing special.  just a bolt with a sealing o-ring - that can be replaced.   I will install new orings and sealant when I mount that adapter plate to xmission.
I found this exloded view on another forum I was browsing... pay attention to item 7.
