Author Topic: Cummins Swap Info  (Read 16200 times)
Offline bajaburban
  • Moderator
  • Cummins Guru
Cummins Swap Info
« on: November 14, 2015, 08:38:35 pm »
I haven't been on here in ages, but I know this is a very common topic. I do about 10 swaps a year.  I'm willing to help with any questions you guys might have.
84 Dually Burb 24v nv4500
88 Crew cab 24v Ve nv4500 205 60/14
Re: Cummins Swap Info
« Reply #1 on: November 14, 2015, 09:06:53 pm »
now all we need is buck and get a section for "cummins swaps"
« Reply #2 on: January 05, 2016, 10:12:31 pm »
Offline bajaburban
  • Moderator
  • Cummins Guru
« Reply #3 on: January 06, 2016, 01:17:35 pm »
Thank you Chris. I know how popular these swaps are becoming and just how much bad info there is. I won't let you down.
« Reply #4 on: January 06, 2016, 04:28:14 pm »
if you cant tell im working on moving most if not all the cummins post to this one
« Reply #5 on: January 06, 2016, 09:28:06 pm »
You have been busy Irish!
Offline bryanedp9
« Reply #6 on: June 15, 2016, 12:27:35 pm »
Hey baja, Tim sent me your way. While not a Cummins question, as I'm doing a 6.5/nv4500 swap, I'm curious what it takes to get the clutch set up right. I've got a 4x4 nv4500 that I'll swap to 2wd or trade for one, and maybe do a 4x4 swap with the truck eventually, but the trans will stay 2wd so I can use an older TC with the correct drop and such, if I even go that route. It may stay 2WD.
In either case, I've got the slave and master and pedal from the GMT truck. I'm guessing I'll need a squarebody pedal and master though. Any help on installation is appreciated!
