Author Topic: Loose 4x4 Floor Shifter  (Read 5706 times)
Offline 780K20
  • Diesel Girl of the Great White North
« on: November 16, 2015, 04:29:54 pm »
On my dash the 4X4 light comes on even though it is not engaged at all. I will wiggle the shifter around and the light will go off, but as soon as I go over a little bump it will light up again. The shifter has play and has a vibration and irritating rattle as if gears are making very slight contact. Are there any typical components that wear out that are to be replaced (like a seat/collar) to make it an easy fix or is there more to it? If anyone has a tutorial that would be awesome as well. Thanks!
-Shelby
1980 K20 Mud Truck Project
2004.5 LLY Duramax - lifted, deleted & EFI Live
Offline enaberif
Re: Loose 4x4 Floor Shifter
« Reply #1 on: November 16, 2015, 06:24:47 pm »
What transfer case do you have? That will tell you more troubleshooting steps.
Offline chevybones87
« Reply #2 on: November 17, 2015, 02:34:53 pm »
Omg THAT rattle..it's the only rattle in my whole in cab and is very annoying if you let it get to you
Offline 780K20
« Reply #3 on: November 18, 2015, 11:37:18 am »
NP205 I believe. Every component on that truck is still stock.
-Shelby
« Reply #4 on: November 26, 2015, 12:20:00 pm »
Is the pivot bolt tight? Does the pivot bolt, or shifter have a grease fitting?
