Author Topic: Ignition switch Identification  (Read 3493 times)
Offline bigge31566
« on: November 19, 2015, 11:54:48 am »
Im rewiring  1983 C10 truck and kit calls for wire to battery power , one to ignition accy. one to nuetral safety switch, problem they dont tell you which is which, and there are 9 different blade terminals on steering column. is there a drawing what each blade terminal does
Offline philo_beddoe
  • 77 C-10
Re: Ignition switch Identification
« Reply #1 on: November 19, 2015, 01:18:40 pm »
I would like the answer to this post as well...
« Reply #2 on: November 19, 2015, 01:44:28 pm »
1983 Wiring Manual page 10, top center - schematic illustration of ignition switch connector from the perspective of the connector face (female side).  The ignition switch is outlined directly below it.  Wires are labeled with metric wire size, wire color, and circuit number.
