Author Topic: This dont line up! All OEM..  (Read 11896 times)
Offline philo_beddoe
  • 77 C-10
« Reply #15 on: November 22, 2015, 08:43:41 pm »
I know, i had a mechanic replace with oem covers when he did my valve seals, leaked and then leaked again under warranty. Still leaks in one little spot on pass side firewall end of valve c., lets see if the rtv holds up. If not still under warranty.
Offline enaberif
Re: This dont line up! All OEM..
« Reply #16 on: November 22, 2015, 08:55:01 pm »
You need felpro blue gaskets and t-handlers and spreader bars. Nothing else will fix those leaks.
Surfaces on the head needs to be cleaned spotless with acetone and inside flanges of valve covers cleaned with acetone and then roughed up.
Don't do this it will always leak.
Offline SkinnyG
  • Reducing resale value since 8-track days
« Reply #17 on: November 22, 2015, 09:04:50 pm »
I modified mine to fit my tall valve covers and wherever my air filter housing ended up on the Performer intake.  I just used old 1-1/2" header tubes to move things around.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
  • 77 C-10
« Reply #18 on: November 22, 2015, 09:11:55 pm »
Before the oem, there were edelbrock, which i removed and painted black, used reg felpro gaskets with plain oem tabs to hold down and no leaks. I cleaned the gm valve covers spotless. Anyway, the drivers side is good. Perhaps a little warp to it?
  • 77 C-10
« Reply #19 on: November 23, 2015, 08:29:15 am »
Yup, that's a good setup skinny...
  • 77 C-10
« Reply #20 on: November 24, 2015, 03:32:56 pm »
Update, used a little bead of rtv under edge of valve cover, no leak, not a drop!!
