Author Topic: 76 Chevy with speedometer reading 10 mph low  (Read 7567 times)
Offline Kimper
  • NP203
« on: November 20, 2015, 10:52:58 am »
Heres my issue fellas, my speedometer reads 10mph low no matter what speed I am at but my odometer reads right on when I check it doing mile test with my GPS. Does this mean my speedo gearing is off at the tranny or my speedo is junk?
You shut your mouth when you're talking to me!!!
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: 76 Chevy with speedometer reading 10 mph low
« Reply #1 on: November 20, 2015, 11:19:04 am »
Because your odometer is right, and it gets its reading from the cable your Speedo gauge might be the culprit
I believe Speedos needles need to be indexed to read right meaning there is a short section, say from 0mph to 7mph where the needle only moves a little bit-this bit takes up any "slack" from the cable.
At least that is my understanding, which is why it is not recommended to remove the needle unless necessary
Sent from my LGL34C using Tapatalk
 1986 Chevy K30(under repair)
Offline Kimper
  • NP203
« Reply #2 on: November 20, 2015, 11:52:59 am »
So it sounds like I need to pull the needle off and re index back on the speedometer and then check it, repeat if necessary..
« Reply #3 on: November 20, 2015, 06:02:41 pm »
Different car, but on the early 80's Mercedes, there was a tick mark on the other side of the rest pin, placing the needle to point to that then moving it back to the other side of the pin would index it correctly
Maybe there is a similar way on these speedos, haven't worked on these trucks long enough to know all the ins and outs
Offline philo_beddoe
  • 77 C-10
« Reply #4 on: November 20, 2015, 09:54:24 pm »
speedometer calibration.
My speedometer reads exactly 10 mph under, why?  Pretty sure its factory.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=31810.msg267649#msg267649
Offline Usareke
« Reply #5 on: November 21, 2015, 12:15:18 am »
Mine reads 10 mph higher than I'm actually going.... _-_ from what I've heard the plastic gear can get worn out and cause this or the gear reduction box on the tranny tail shaft could be out a wack
Sent from my SAMSUNG-SGH-I317 using Tapatalk
~ Zach
Offline Kimper
  • NP203
« Reply #6 on: November 24, 2015, 02:41:09 pm »
Thanks for the info guys, I guess I will start with the gear and see what that looks like. I know it has a rebuilt Th350 in it but I am not sure if it's the one from the factory..
