Author Topic: Wiper motor wiring  (Read 7517 times)
Offline bigge31566
Wiper motor wiring
« on: November 21, 2015, 01:09:20 pm »
Im rewiring my 1983 c10 intermitt. wiper motor and have a few questions, Ive located all the wires pink 94, ppl 92, blk 150, blk/blu 97, and the gray 91, the only thing that Im not sure of is white 93, would this be the power to run motor and washer
Online bd
Re: Wiper motor wiring
« Reply #1 on: November 21, 2015, 01:42:03 pm »
Correct.  It comes directly off of the wiper fuse.
Offline bigge31566
« Reply #2 on: November 22, 2015, 07:49:22 am »
My kwikwire kit is suppling power to the wiper switch, do you split off of this wire and catch washer sol., and the wiper motor, since not using old fuse block
Online bd
« Reply #3 on: November 23, 2015, 10:11:23 pm »
Did your kit come with instructions and tips?
The OEM didn't supply power to the wiper switch.  Power fed directly to the wiper motor and w/washer.  The dash switch just controlled the ground connection.  Are you sure that what you think is power to the switch isn't just the ungrounded return from the wiper motor?
Offline hatzie
« Reply #4 on: December 03, 2015, 10:09:32 am »
I explained how the stock wiper switch and motor are wired in this thread.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32195.0
