Author Topic: Brake tube size  (Read 20935 times)
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Brake tube size
« on: November 24, 2015, 05:12:44 pm »
Working on my 1985 GMC longbed. I ordered up a 25' roll of each 1/4 and 3/16 tube, Cunifer/copper-nickel. I stupidly apparently threw out the lines from the master to the prop. and I think both front lines. but anyways, can someone confirm that 1/4" and 3/16" is all I need for the brake lines. I will be getting 3/8" and 5/16" later for fuel lines. So if needed to be factory correct I will get more of the right size,
I believe it is 3/16 MC to PV for front brakes, 1/4 MC to PV for rear, 1/4 for the main rear line, and 3/16 for all four corners, can a couple people confirm this?
Oh I will be converting to Hydro-boost(diesel) from original Vacuum booster if that ends up playing a part in line size
Thanks all
 1986 Chevy K30(under repair)
Offline enaberif
Re: Brake tube size
« Reply #1 on: November 24, 2015, 05:58:45 pm »
1/4 from master to prop
3/16 for everything else
Re: Brake tube size
« Reply #2 on: November 25, 2015, 04:28:56 pm »
I'll have to check tomorrow, But I am sure the main line to the rear was 1/4"
Offline enaberif
Re: Brake tube size
« Reply #3 on: November 25, 2015, 05:50:39 pm »
Oh yes you are right! I forgot about that one.
1/4" with 9/16" and 1/2" fittings at the master cylinder and prop
3/16 from prop to front brakes
1/4" from prop to rear connector
Soft brake line from 1/4 line to axle then 3/16 from there to wheel cylinders.
Just did this myself.
Re: Brake tube size
« Reply #4 on: November 25, 2015, 06:11:34 pm »
Cool, thanks.
did you have to get a new prop/combo valve? I think I do, and need the right part number, I found a couple different numbers, but don't know?
1/2 ton, will be getting a 1-ton master and hydro-boost-although I may need a new master too-depends on how it looks when I pull it, so I assume the 1/2 ton hydro master will mount up fine to the 1 ton hydro-booster
I believe 11-15/32 brakes as well, need to double check
Offline enaberif
Re: Brake tube size
« Reply #5 on: November 25, 2015, 07:34:53 pm »
Yeah I needed a new combo unit. Got a CPP unit.
