Author Topic: Th350 shifting way late  (Read 13682 times)
Offline Joec123able
« on: November 25, 2015, 07:44:29 pm »
My 77 k-10 shifts ridiculously late. It doesn't shift from first to second until 35 mph and at that point, it's revving so high it's almost almost redlining. It's a fun truck to drive but that just ruins it for me. Also I pretty much can't coast in it I have to basically stomp it til it shifts to the next gear then I can coast. Otherwise it will stay in gear and it feels like it's holding you back while coasting. Any ideas? I changed the trans fluid and filter and that had no effect on it.
Re: Th350 shifting way late
« Reply #1 on: November 25, 2015, 07:52:57 pm »
Check the vacuum line to the transmission modulator valve.  The rubber hoses at each end of the steel line have a tendency to swell and loosen or split.  Make sure the steel line isn't perforated.  While you are there, peer into the vacuum port of the modulator valve to see if there is any trace of red transmission fluid - replace the valve if there is and recheck the fluid level.
Offline Joec123able
« Reply #2 on: November 25, 2015, 07:55:58 pm »
How would I check if there's a vacuum leak?
« Reply #3 on: November 25, 2015, 09:27:09 pm »
Begin by inspecting the short 5/32" rubber hose at the modulator valve and the 1/4" rubber hose at the intake manifold vacuum fitting behind the carburetor.  Then inspect the connecting steel line for any obvious physical damage (e.g., rust, rubbing, breaks, etc).  If the steel line is still questionable following visual inspection, plug one end of the line and draw a vacuum on the other end to see if the line will hold vacuum.  With the line properly connected at both ends you could also spray the line with some B12 or similar aerosol while the engine is running to see if there is an RPM change - but watch out for exhaust heat.
Offline Joec123able
« Reply #4 on: November 25, 2015, 09:36:32 pm »
Thanks a lot for the help! I'm gonna check that out, and probably just go ahead and replace the modulator valve and hope that solves it!
Offline Engineer
« Reply #5 on: November 25, 2015, 10:04:29 pm »
Do what bd suggested first and let us know what you find.
If that doesn't fix your issue you may have a governor problem.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline rich weyand
« Reply #6 on: November 26, 2015, 09:56:50 am »
1) Replace both hoses first.  Cheap, and usually the cause of the problem.
2) Change the modulator.
3) Modify the governor.
You don't say whether this is a new problem, or existed when you got the truck.  If it was already a problem, the governor may have been modified already by an IPO who didn't know what he was doing.
Offline Joec123able
« Reply #7 on: November 26, 2015, 05:25:27 pm »
It's an all time four wheel drive truck and it has had that problem since I got it. I honestly don't know anything about the governor so I wouldn't know where to start with that but I'm gonna try to replace the modulator and fix any vacuum leaks tomorrow I'll let y'all know if it works out.
Offline Joec123able
« Reply #8 on: November 27, 2015, 02:32:18 pm »
Okay I just found something on the trans that may be the cause, I found the metal line with a rubber end and there's a little nipple that it plugs onto on the transmission and it isnt hooked up, is that the vacuum line? If so it isn't even hooked up!!
« Last Edit: November 27, 2015, 03:08:18 pm by bd »
Offline Joec123able
« Reply #9 on: November 27, 2015, 03:38:41 pm »
She's fixed!!! I'm so happy, it was just the vacuum line unhooked! Lol I'm so glad now it drives like a normal truck
« Reply #10 on: November 27, 2015, 03:40:29 pm »
Good job!  Make sure the vacuum hose is a tight fit on the modulator valve so it doesn't come loose again.
Offline Joec123able
« Reply #11 on: November 27, 2015, 04:41:51 pm »
Thanks so much for the help, getting that fixed made my week! So happy. I've had to fix a lot on this truck since I bought it but now getting that fixed, it's finally atleast a drivable truck.
« Reply #12 on: November 27, 2015, 04:59:45 pm »
You are quite welcome.  Happy to help!
Offline Dr_Snooz
« Reply #13 on: November 28, 2015, 08:21:23 pm »
4) Check the kickdown solenoid.
I know the issue is resolved now, but for posterity, if the kickdown mechanism fraps out, it won't shift until 4k. At least that was the problem on my TH400.
« Reply #14 on: November 28, 2015, 08:41:08 pm »
TH350 doesn't use a detent solenoid.
