Author Topic: No oil pressure at start up  (Read 4996 times)
Offline chevybones87
« on: November 26, 2015, 07:59:16 am »
Ok I have a 1980 k10 4.1L 250.. When I start it up cold to warm it up it has no oil pressure for about 5 mins the all of a sudden jumps to 50.. Its worrying me so any advice would be great.. Thanks guys.... ALLEN
Re: No oil pressure at start up
« Reply #1 on: November 26, 2015, 08:04:40 am »
More than likely it is a sluggish gauge
« Reply #2 on: November 26, 2015, 12:15:10 pm »
         ... or sending unit.
Unplug the sending unit wire from the sender and connect an ohmmeter between a good clean ground (such as the metal body of the sender) and the sender terminal.  Set the parking brake and have an assistant start the "cold engine" while you monitor the ohmmeter.  Stay clear of the fan and belts.  The sender should measure approximately zero at zero oil pressure, before starting the engine; 30 ohms at the center line of the gauge and 60 ohms at the maximum line of the gauge.  If the sender responds immediately when the 'cold engine' starts and measures 30 plus ohms, the issue is in the gauge or its wiring.  If the sender is sluggish to register pressure, remove the sending unit and thread in a reliable mechanical test gauge to verify the oil pressure.
« Reply #3 on: November 26, 2015, 12:44:20 pm »
Ok ill give it a shot but not to sound like a dummy but where is the sender and could you describe it I'm new to this. Its a 1980 k10 with the 4.1 i6... Thanks alot guys yall have already helped alot with various other things I've read
« Reply #4 on: November 26, 2015, 01:01:16 pm »
Located on the passenger side of the engine block and has a single, tan colored wire connected to it.
« Reply #5 on: November 27, 2015, 07:28:49 am »
Great thanks alot it was my gauge.. Swapped it out good to go
« Reply #6 on: November 27, 2015, 10:01:21 am »
Great!  Thanks for letting us know the outcome.
