Author Topic: check engine light does not work  (Read 3305 times)
Offline NCali
« on: December 12, 2015, 09:47:59 pm »
87 2wd 1/2 ton 305 tbi
I checked the timing today and as per instructions , I disconnected the EST connector before I started.  Disconnecting that plug  should have been reason enough for thecheck light to come on[/It did not
I plug the connector back together and the light didnt even come on when the key switch was  turned to the on positiom
  I tried to jump  the connector under the dash  and that didnt work either
The ecm and ignition fuses look good, are there any other fuses or links that power up the computer?
Black Labs Matter
Offline LTZ C20
Re: check engine light does not work
« Reply #1 on: December 12, 2015, 10:59:33 pm »
Have you removed the dash bezel housing with the check engine light in it and checked the bulb? Maybe the bulb is burnt out, if my SES lite stopped working, the first thing I would check would be the bulb.
LTZ Cheyenne C20
Offline big_al273
« Reply #2 on: December 13, 2015, 04:47:16 pm »
seconded, start with the easy stuff
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
« Reply #3 on: December 13, 2015, 04:48:58 pm »
yes if the light doesnt light up when you turn the ignition "on" then suspect a burnt bulb
