Author Topic: Another wiring question  (Read 3425 times)
Offline Rattler12
  • Old Geezer
« on: December 13, 2015, 05:29:24 pm »
!983 Chevy C-10 originally had a 4.1/250 ci 6 cylinder. Its out and a big block has taken its place. There is 3 wire plug than ran along side the wiring to the solenoid which had a pink, a green and a blue wire that plugged into the block just above and a bit in front of the starter. Anybody know what it is for?  Obviously there is no where on the BB above the starter to plug it into. Any problems if I just tape it up and tuck it away?  Thanks
Rattler
83 C-10 shorty 454, 5spd, 3:73 posi
Online bd
Re: Another wiring question
« Reply #1 on: December 14, 2015, 05:30:07 pm »
This is just a WAG, but if the three wires enter a two-cavity connector, it may attach to the two-prong oil pressure switch for the electric choke heater.  Factory color coding for that circuit is pink/white, dark blue and light blue with the dark and light blue wires sharing a terminal.  Heat and oil soaking over time can cause the light blue insulation to take on a green appearance.  If it is for the electric choke and the BB you installed uses an electric choke carburetor, it could benefit you to reuse the circuit.  To determine whether it is for the choke heater, with the CHOKE fuse installed in the fuse box, switch ON the ignition and check the pink wire for 12 volts.  With ignition still ON, grounding the dark blue wire should cause the choke lamp in the instrument cluster to illuminate.
Offline Rattler12
  • Old Geezer
« Reply #2 on: December 14, 2015, 05:57:56 pm »
Thank you kind sir.....did not know there was a separate oil pressure switch  for the electric choke
