Author Topic: POWER WINDOW CONVERSION??????????  (Read 26621 times)
Offline kfoz
  • ALWAYS BUILD WITH BRICK & STONE ! ! !
« on: December 15, 2015, 09:35:23 am »
Who has done this & are there better conversions kits over others???
ALSO, Ecklers says with their kit you must use 78-87 window sash's for the conversion???
My truck is a 1976 GMC!
A friend of mine has an account with good discounts at Eckler truck so I may go with that.
ANY SUGGESTIONS?
Thanks all!  :)
kfoz (kfoz@comcast.net)
'73 C20 4 Speed 2WD
Offline LTZ C20
Re: POWER WINDOW CONVERSION??????????
« Reply #1 on: December 15, 2015, 02:03:17 pm »
I put factory power windows and locks from an 85 in my truck. Wiring, motors, swirches everything. It all Works no problem. I would only use factory stuff, never had to deal with aftermarket kits.
LTZ Cheyenne C20
Offline kfoz
« Reply #2 on: December 15, 2015, 05:16:49 pm »
Well, I do have an '83 truck I could take that from BUT the motors are weak & one doesn't work.  Maybe the switch??
'73 C20 4 Speed 2WD
« Reply #3 on: December 15, 2015, 09:10:17 pm »
When you perform the conversion, I strongly recommend integrating relays into your plan.  Augmenting the factory wiring with relays results in a world of improvement and longer service life for the motors.  See Wiring up power windows and door locks.
Offline LTZ C20
« Reply #4 on: December 15, 2015, 10:19:07 pm »
When I got the parts for mine, I had 1 weak motor, it was the drivers side. I swapped it with the passenger side, when it finally stopped working, I replaced it. Drivers is still working. I wouldn't let one non working window stop you. If you have a donor with all the parts, things can be fixed. You just have to be logical with your diagnosis of the issue.
LTZ Cheyenne C20
Offline LTZ C20
« Reply #5 on: December 15, 2015, 10:19:26 pm »
Also, I recommend this too.
LTZ Cheyenne C20
« Reply #6 on: January 06, 2016, 09:57:12 pm »
73-76 trucks never came with power windows.  If it isn't the factory setup I don't know that I would do it...  Just depends on the lift motor style.  77-91 doors were redesigned to allow power windows.
