Author Topic: Stepside filler neck  (Read 9121 times)
Offline retiredtr6
« on: March 14, 2005, 07:05:00 pm »
Does anyone know where I can find a filler neck for my 81 Stepside? Can't seem to find one locally.
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
Truck
« Reply #1 on: March 14, 2005, 10:29:00 pm »
Check out www. competitor.com , they should have it.
Hope this helps!
-Mike
Offline retiredtr6
Re: Truck
« Reply #2 on: March 14, 2005, 10:32:00 pm »
Thanks Mike;
Called them today and they say their rubber filler hose is for the fleetside only. Year One only lists up to 1980?
Re: Stepside filler neck
« Reply #3 on: March 15, 2005, 06:58:00 am »
Can you match up your old one to a similar shaped radiator hose?
Offline retiredtr6
« Reply #4 on: March 15, 2005, 08:48:00 am »
That's my next step. I have a friend that has about 500 older radiator hoses that are NOS, Imay try to match some of them.
Thanks
Offline 77c15
neoprene
« Reply #5 on: March 15, 2005, 10:39:00 pm »
The fuel hose has to be a neoprene injected hose or it will slowly, but absolutely eventually, eat away and cause a massive leak when you fill up one day. I rigged my old 77 up with a rad hose and got leaks after only 3 fillups with high-octane!
-Mike
Offline 80stepsideguy
« Reply #6 on: March 25, 2005, 02:46:00 pm »
I think 1980 will work since they should interchange,best bet to take it off and compare it to the 80 one.
thanks
pat
1998 Chevy 1500 S/B 2wd
