Author Topic: Square parking light mounting??  (Read 5366 times)
Offline Centexhunter
« on: December 22, 2015, 06:04:36 pm »
First of all...great forum. I'm learning a lot here! I've got a 1985 c20 that I just picked up. I'm pretty sure that it does not have the original grill in it (it's a 4 headlight setup) and has the square parking lights. The previous owner had the parking lights taped in place with duct tape!  I want to mount them correctly, but can't figure out how. I'm guessing that I have incompatible parts but have no idea. I see that there are two mounting tabs on one side of each light but where do they mount?
Any advice greatly appreciated and if anyone has a picture of how theirs mounts, that would be awesome! Thanks
Re: Square parking light mounting??
« Reply #1 on: December 23, 2015, 12:47:07 pm »
I'm thinking that the grille currently on the truck is from an early 80's model. Perhaps that is the reason ?
Offline timthescarrd
« Reply #2 on: December 23, 2015, 01:00:40 pm »
The proper grill would have a slot at the bottom on each side that the tab of the lights slides into and two posts at the top on each side that those tabs go over, then a nut screws onto to hold them in place.   If it's not the grill for a 4 headlight model, those won't be there
« Reply #3 on: December 23, 2015, 04:05:16 pm »
Thanks!  I had a strong feeling that the grille was not the correct one.  I will now be on the lookout for one that will work...(and in the meantime...the duct tape is still holding! lol).  ;D
« Reply #4 on: December 24, 2015, 05:32:56 pm »
Found a correct grille and will be installing soon.  It's pretty obvious how they mount when you have the right grille!!  :-[
thanks again for putting me on the right track.
« Reply #5 on: December 25, 2015, 08:06:59 am »
I have hot glued, & also epoxied the lights into the wrong grille in the past.
