Author Topic: cracked head ? Block or head gasket?  (Read 4778 times)
Offline NCali
« on: December 26, 2015, 07:40:47 pm »
87 1/2 ton with a 305 tbi
truck runs fine until the thermostat opens, then it billows out clouds of white steam out of the tail pipe. Shut it off at that point and when I try to restart it there is enough water in what ever cylinder that it wont turn over , it just locks up, . 10 minutes later it will start again
my question:  cracked head, block or head gasket
Black Labs Matter
Re: cracked head ? Block or head gasket?
« Reply #1 on: December 26, 2015, 08:28:48 pm »
Pull it apart the only way to tell.
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #2 on: December 27, 2015, 09:18:47 am »
definitely have to pull it apart to find out...when you pull your spark plugs look for the one that shows water on it...then when you pull the heads off you know which cylinder to really look at...i just had to replace the heads on my 350....one was cracked between the intake valve and the water jacket.
Offline NCali
« Reply #3 on: December 27, 2015, 03:16:04 pm »
so it is not apart yet but I have the exhaust off of 1 side and#4 and #6 are wet
Black Labs Matter
Offline SkinnyG
  • Reducing resale value since 8-track days
« Reply #4 on: December 27, 2015, 04:33:16 pm »
Post pictures of your head gaskets too.  That may help.  Look especially close for cracks between the valves and/or into a spark plug hole.
Mine were blown (see the dark patches):
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Offline Rattler12
  • Old Geezer
« Reply #5 on: December 27, 2015, 07:15:18 pm »
Most likely a head gasket if 4 and 6 are wet......
83 C-10 shorty 454, 5spd, 3:73 posi
Offline NCali
« Reply #6 on: January 03, 2016, 10:13:35 am »
Long crack between the water jacket and exhaust valve on #6 on the face of the head next to the egr port
Black Labs Matter
