Author Topic: 85 C10 widest rim and tire setup  (Read 22939 times)
Offline GaryLT1
« on: December 31, 2015, 07:48:29 pm »
So... I have a 85 C10 LS/TH400 with a 12 bolt we all know these trucks have a super narrow rear end and look horrible from behind... So I was looking into a 315/60R15 mickey dot drag radial with a 15x10x4bs rim for the setup. Now I don't want to narrow my rear or frame and I'm running stock suspension since I'm going for the sleeper look so I need input and pictures before I order so I get the correct setup cause google isnt helping so please I need input
Re: 85 C10 widest rim and tire setup
« Reply #1 on: January 01, 2016, 12:07:00 pm »
With the right backsapcing you can fit a 14" wide tire under these...
Did you search the forum?  Best way is to go to google and put for example:  widest tire site:73-87chevytrucks.com  In the search.  Change whatever you want in front of site to search other things.
Here is a pretty good thread on it:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=25405.0
