Author Topic: 1984 GMC K1500 SM 465 shifting issue...  (Read 2684 times)
Offline ArmourK1500
« on: January 01, 2016, 02:34:36 pm »
I have a SM 465 in my truck. The issue is when the truck has sat overnight, it shifts very well into reverse and thru all the gears while driving. But after a couple hours of running errands, stop here and there, it starts to have a hard time shifting into reverse and into gear while driving. I thought it was my clutch pedal bushing since I had so much side to side play that was causing the shifting problem. After replacing the bushing and test driving today I still have the same shifting problem. What can I check? Mechanical Linkage next? Thanks and Happy New Year
Offline Captain Swampy
  • Wisconsin
Re: 1984 GMC K1500 SM 465 shifting issue...
« Reply #1 on: January 01, 2016, 06:36:51 pm »
Try changing the oil. I recommend Amsoil, but any good quality oil will work. Maybe the input bearing is worn from the bad pilot bushing?
