Author Topic: cannot identify these pistons, Please Help  (Read 4034 times)
Offline Boxchevrolet
« on: January 02, 2016, 04:51:28 pm »
hello, im in the process of getting my 350 rebuilt and i cannot find out if it has been bored out before and i can't find a piston size on the pistons, the only thing they say is on the inner skirt and it is M-567, nothing on the top, any help is greatly appreciated
Offline Peter S
Re: cannot identify these pistons, Please Help
« Reply #1 on: January 02, 2016, 07:26:27 pm »
Just measure the piston.
-Peter
1978 K10 stepside
« Reply #2 on: January 02, 2016, 08:47:27 pm »
how so?
Offline Engineer
« Reply #3 on: January 02, 2016, 09:11:41 pm »
Your machine shop should be able to measure it for you. I've never seen a GM piston that looked like that. It is cast and nothing at all fancy or race.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline roboticjunky
« Reply #4 on: January 02, 2016, 09:20:28 pm »
IMO, it's probably standard bore. Look this piston. http://www.competitionproducts.com/Cast-Aluminum-Pistons-Chev-SB-350-Dished-4VR-4000-Bore-3480-Stroke-5700-Rod/productinfo/P567S/#.VoiSJ1J4JpA
Other ones by this brand would have the overbore number added to the end. (Like bored .30 over would be P56730)
I understand yours has a M instead of a P, but could be an old part number.
1987 V10 Silverado 350 HSR
Offline timthescarrd
« Reply #5 on: January 02, 2016, 09:47:41 pm »
You are better off mearsuring the bore of the block than the piston.  A 350 should have a 4.000 inch bore.  Use some calipers to measure straight across the openings.  Bored out would be 4.010 - 4.060
« Reply #6 on: January 03, 2016, 12:45:58 pm »
i measured the top and bottom of the piston and averaged a 4.034 bore, which leads me to think it has been bored .040 before, so now i reckon ill go .060 over hopefully
