Author Topic: is this a position unit?  (Read 3039 times)
Offline Mikeymike383
« on: January 02, 2016, 08:11:11 pm »
Is this a position 12 bolt rearend
383 stroke
Re: is this a position unit?
« Reply #1 on: January 02, 2016, 08:16:42 pm »
That is the standard open differential, not posi-traction.
« Reply #2 on: January 02, 2016, 08:27:54 pm »
thanks I just wanted 2 make sure b4 I sealed it up
383 stroke
« Reply #3 on: January 03, 2016, 06:48:55 am »
in most cases if you jack up the rear end and turn one wheel if the other wheel turns in the same direction its a posi if they turn on opposite directions is more than likely a open
